Parsing error while using the following loop
Old   August 26, 2018, 04:28
Post Parsing error while using the following loop
Saurabh Das
Sorabh is on a distinguished road
Hello, I have recently stepped into the realms of udf. After a few successive tries, I was told to model pulsed laser.
#include "udf.h"
#define PI 3.1415926 //Pi, a constant
#define sigma_q 0.35 //Absorptivity
#define I 1.05e9    //Laser power
#define R 5.250e-3 //Radius of laser beam
#define v 3.000e-3 //Scanning velocity
#define tr 1e-6
#define tc 50e-6
#define tf 1e-6
#define tp = 100e-6
DEFINE_PROFILE(heat_flux_momin1,thread,position)
    face_t f;
    double x[ND_ND], ft, time, vol, r, t, tempp;
    double a = 2*R/3;
    time = RP_Get_Real("flow-time");
    t = RP_Get_Real("laser-pulse-time");
    begin_f_loop(f,thread)
        tempp = F_T(f,thread);
        F_CENTROID(x,f,thread);
        r=sqrt(pow((x[0]),2.0)+pow((x[1]),2.0));
        while (t <tp)
        if (t =0) {ft = 0;}
        else if (t < tr) { ft = time/tr;}
        else if (t <= (tr + tc) && time >= tr) {ft = 1;}
        else if (t < (tr + tc + tf) && time > tr + tc) {ft = (tr+tc+tf-t)/tf;}
        else  {ft = 0};
        t = time -tp ;
        vol=2.0*r*r/(a*a);
        F_PROFILE(f,thread,position)=(2.0*I*sigma_q*exp(-vol)*ft; //Set face flux
        end_f_loop(f,thread)
This returns the following errors when interpreted by Fluent.
Error: C:/Users/NEWU~1/AppData/Local/Temp/MominHeatFlux3.c.8748.0.c: line 25: parse error. Error: C:/Users/NEWU~1/AppData/Local/Temp/MominHeatFlux3.c.8748.0.c: line 28: parse error.
Error: C:/Users/NEWU~1/AppData/Local/Temp/MominHeatFlux3.c.8748.0.c: line 29: parse error.
Error: C:/Users/NEWU~1/AppData/Local/Temp/MominHeatFlux3.c.8748.0.c: line 30: parse error.
Error: C:/Users/NEWU~1/AppData/Local/Temp/MominHeatFlux3.c.8748.0.c: line 31: parse error.
Can anyone please help me out with this? Thank you.
Sorabh is offline   Reply With Quote
Old   August 26, 2018, 21:53
blackmask will become famous soon enough
I have corrected the syntax error for you.
#include "udf.h"
#define tr 1e-6
#define tc 50e-6
#define tf 1e-6
#define tp 100e-6
    face_t f;
    double a = 2*R/3;
        while (t <tp)
            if (t == 0) {ft = 0;}
            else  {ft == 0;};
        t = time -tp ;
        vol=2.0*r*r/(a*a);
        F_PROFILE(f,thread,position)=2.0*I*sigma_q*exp(-vol)*ft; //Set face flux
blackmask is offline   Reply With Quote
parse error, udf
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 02:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
