Plasma UDF
Old   July 24, 2018, 14:01
Default Plasma UDF
Nabat is on a distinguished road
I want to simulate a plasma on two sides of the cylinder in -90 and 90 degree locations with duty cycle 50%. I wrote it with IF and Loop but it is not working. I would be thankful if you could guide me where is my mistake. I would be thankful if you could guide me.
Nabat is offline   Reply With Quote
Old   July 24, 2018, 21:39
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
something wrong with your UDF
best regards
AlexanderZ is offline   Reply With Quote
Old   July 24, 2018, 22:57
best regards
Yes, but I could not find what is it. Could you guide me. Here it is.
Regards
#include "udf.h"
#define con 1000
DEFINE_SOURCE(plasmasource,cell,thread,ds,eqn)
real x[ND_ND];
real t;
real source;
cell_t c;
real y;
t=CURRENT_TIME;
/*Now making source not dependant on velocities where con[N/m^2]*/
begin_f_loop(c,t)
C_CENTROID(x,cell,thread);
y=sin(t);
if (y>0.)
if(x[0]>-.001 && x[0]<.001 && x[1]>.0127 && x[1]<.0128)
source=con;
ds[eqn]=0;
else
{ source=ds[eqn]=0;}
else
return source;
end_f_loop(c,t)
begin_f_loop(c,t)
y=sin(t);
if (y>0.)
source=con;
ds[eqn]=0;
else
else
return source;
end_f_loop(c,t)
Old   July 26, 2018, 01:38
Alexander
I can only guess, what exactly you want. May be this code is OK for your case
#include "udf.h"
#define con 1000
real x[ND_ND];
real t;
real source;
real y;
t=CURRENT_TIME;
y=sin(t);
if (y>0.)
source=con;
ds[eqn]=0;
else
{source=0; ds[eqn]=0;}
else
return source;
best regards
Old   July 26, 2018, 15:48
Thank you for your guidance. Could you tell me why we do not need loop for different time steps. I also attached my geometry in which the locations of 2 plasmas are shown. Should I add one more if, to add the second plasma? Thank you very much for you time.
Old   July 27, 2018, 02:02
Alexander
in your original code there was no lopps for different time steps. There was loop over faces of domain (which is not needed here and was implemented in wrong way. For more information look into Ansys Fluent Customization manual)
Macro DEFINE_SOURCE contains cell and thread as arguments, so using this macro you define source value on each specific finite volume element of mesh. Loop over elements is not needed.
You may add as many locations, as you want. In your first code coordinate values were exactly same, that's why I've deleted second IF statement
best regards
UDF for vapor pressure anuarun Fluent UDF and Scheme Programming 13 June 23, 2024 14:12
Replicating Scalable Wall Function with a UDF yousefaz FLUENT 0 August 4, 2017 03:30
udf for biomass plasma gasification xlwmoaggouri Fluent UDF and Scheme Programming 0 January 10, 2014 15:45
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
