July 21, 2018, 06:18 |
Rotating speed control by UDF
mamly
Rep Power: 16 |
Hello
I am simulating a wind turbine which rotates by wind velocity (wind velocity is an initial parameter). I have simulated this problem by ANSYS fluent and using dynamic mesh. Now, I want to control the rotating speed of turbine's blades by a UDF code. I mean, by passing the time, the rotating speed increases up the the maximum value, but I want to fix the rotating speed on a specified value for example in rmp=100. I appropriate if anybody could help me! Best |
dynamic mesh, udf code, wind turbines |
Rotating Cylinder UDF | greg_2666 | Fluent UDF and Scheme Programming | 0 | February 11, 2016 10:33 |
Dynamic mesh for rotating wall - UDF ? | Tobard | FLUENT | 1 | April 28, 2011 19:00 |
question about governing equation in CFX using rotating/non rotating reference frame | rystokes | CFX | 0 | January 12, 2010 07:14 |
UDF for changing angular speed | ILia Skryabin | FLUENT | 1 | November 12, 2007 22:02 |
UDF to propagat VOF interface at a specified speed | Johann | FLUENT | 1 | May 27, 2006 12:39 |
