Oscillating liquid piston with known frequency and amplitude |
Beric Anissa
Rep Power: 8 ![]() |
I'm trying to modelize an oscillating liquid piston. I want to study the surface of the liquid according to the frequency and the amplitude of the piston. I need to use a dynamic mesh and create a sine motion for the piston. I want to use the following C code to program this motion: #include "udf.h" DEFINE_PROFILE(unsteady_velocity, thread, position) { face_t f; real t = CURRENT_TIME; begin_f_loop(f, thread) { F_PROFILE(f, thread, position) = 0.05*sin(3.14*t); } end_f_loop(f, thread) } However, I'm not sure of the units of the amplitude and the frequency I'm using. How can I know if 0.05 is in mm, cm, m ? Also my simulation is not working well and I haven't seen if the piston is really moving up and down following a sine wave. Is the code correct ? Thanks for your help |
Rep Power: 18 ![]() |
Fluent uses SI base units and therefore length scales are in metres and time is in seconds. The DEFINE_PROFILE macro is used for changing flow variables such as velocity to impose on a boundary condition (e.g. inlet). The dynamic mesh uses a different set of macros, see "Dynamic Mesh DEFINE Macros" in the UDF manual for reference.
Beric Anissa
Thank you for your reply,
I've checked all the possible macros and maybe you think that DEFINE_CG_MOTION is more suitable to define a piston motion ? |
Beric Anissa
As I am working in 2D, if the piston motion is given by: y=A*sin(wt), the code will be:
#include "udf.h" DEFINE_CG_MOTION(piston_motion, dt, vel, omega, time, dtime) { real A, w, pi; pi = 3.14; NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); A = 0.005; w = 2 * pi * 1; /* 1Hz frequency */ vel[0] = 0; vel[1] = A * sin(w*time); } Is that correct ? |
Is y a position or velocity? The DEFINE_CG_MOTION uses velocities. For an example of using this macro for a piston motion, see: CG Motion UDF Problem
Amplitude spectrum of temperature fluctuations | selvam2487 | CFX | 0 | March 16, 2014 13:59 |
FSI oscillating plate | spatialtime | CFX | 4 | April 29, 2009 15:04 |
urgent! amplitude and frequency | Sheila | FLUENT | 3 | June 22, 2006 11:23 |
