UDF error message: C_PB_DISCI(c,t, i) undeclared variable |
July 5, 2018, 18:05 |
Rep Power: 8 |
I am trying to access the PBE bin fractions using C_PB_DISCI(c,t, i) in population balance add-on module. When I interpret the UDF, it shows an error message "undeclared variable c_pb_disci". If I include sg_pb.h, a new error message will come up "line 123: parse error".
I think the problem is macro C_PB_DISCI(c,t, i), because when I replace this with other cell variables there are no more errors. I have copied the code below. Thanks in advance for your help. include "udf.h" #include "sg_mphase.h" /*#include "sg_pb.h"*/ #define mu 0.0014 #define sdas 0.00155 DEFINE_SOURCE(SRCE_Xmom,cell,thread,dS,i) { real source; real fs,a,b,c,d,e,f; real k; Thread *tm = THREAD_SUPER_THREAD(thread); Thread *ts; ts = THREAD_SUB_THREAD(tm,1); a = C_PB_DISCI(cell, ts, 0); b = C_PB_DISCI(cell, ts, 1); c = C_PB_DISCI(cell, ts, 2); d = C_PB_DISCI(cell, ts, 3); e = C_PB_DISCI(cell, ts, 4); f = C_PB_DISCI(cell, ts, 5); /* calculate the maximum volume fraction of secondary phase between all the bins*/ if(a>b && a>c && a>d && a>e && a>f) {fs=a;} else if(b>a && b>c && b>d && b>e && b>f) {fs=b;} else if(c>a && c>b && c>d && c>e && c>f) {fs=c;} else if(d>a && d>b && d>c && d>e && d>f) {fs=d;} else if(e>a && e>b && e>c && e>d && e>f) {fs=e;} else if(f>a && f>b && f>c && f>d && f>e) {fs=f;} k = sdas * sdas /180.0 *(1-fs)*(1-fs)*(1-fs)/(fs*fs); source= -mu/k*C_U(cell,thread); dS[i] = -mu/k; return source; } |
July 6, 2018, 04:58 |
Rep Power: 12 |
Hi Pooneh61,
I would not expect interpreting to work for these UDFs. You need to install a (free) compiler. There are some useful posts on compiling UDFs -- for example: links to instructions Visual Studio 2017 for udf use - which modules do I need?; troubleshooting errors How to solve UDF compilation problems in Fluent.; the basic steps of compile/load/hook The UDF library you are trying to load (libudf) is not compiled for 3D on the current. A couple of comments on your code: • Your big set of "if" statements to find the largest value looks correct, except that it will fail to put any value into fs if the two largest values are equal. Maybe this is unlikely (*except* if someone initialises the values that way, when it becomes very likely), but it is bad practice in general. Also, of course, it would become increasingly tedious if the number of intervals extended beyond 6 (which is a small number of intervals). See if you can find a solution using a for() loop. • Using the maximum value of C_PB_DISCI seems strange to me from a physical perspective. First, is it really reasonable that the drag is defined by a value of 0.6 in bin3 (for example), regardless of whether there is a value 0.4 in bin2, or 0.4 in bin4, or small values in all other bins? Second, please note that C_PB_DISCI values are not volume fractions -- they are proportions of the volume fraction of that secondary phase. The sum of the full set of C_PB_DISCI values should always be 1.0. Good luck! Ed |
July 20, 2018, 14:43 |
#3 | |
Rep Power: 8 |
Thanks a lot. The issue is solved by compiling the UDF file in fluent 17, but still I have problem in fluent 15. I get this message: "'nmake' is not recognized as an internal or external command", which probably related to some installation settings in fluent. |
Can I change the variable in UDF via Fluent console or window without compiling? | swtbkim | FLUENT | 0 | July 12, 2017 23:15 |
A UDF for mixture outlet variable derived from two other input parameters? | ebtedaei | FLUENT | 0 | July 12, 2017 03:17 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 10:14 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 05:35 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
