Using compiled case and data file in another fluent software
Old   June 22, 2018, 17:41
Default Using compiled case and data file in another fluent software
Anomymous
Nishant_Sharma is on a distinguished road
Hi all,
I want to ask whether we can use case and data file which is compiled in a fluent into another pc, also if the version of the fluent is different (lower mainly)
I want to use it as while compiling the udf, it is showing the error 193 (I read about it on this forum, but the error still persists), i.e., the lib is not loading. I tried opening fluent through vs command prompt, but the error still persists.
Thank you
Nishant_Sharma is offline   Reply With Quote
Old   June 23, 2018, 01:56
`e`
`e` is on a distinguished road
Loading case and data files from older releases of Fluent should work. Typically, you should re-compile the UDF, see my compiling process for Fluent UDFs with an existing library loaded.
`e` is offline   Reply With Quote
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
Case and Data file reading is failed in Fluent 6 mqasimali FLUENT 0 March 6, 2013 08:08
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 17:31
