using one uds in other uds
Old   June 18, 2018, 18:01
Default using one uds in other uds
Animesh Sahoo
sahoo is on a distinguished road
hello everyone,
Actually I am trying to code the following equation :-
[∇α(T)]TJ=-∇UDS2 T/ρ(T) ∇UDS0
So, I need to use UDS0 & UDS2 in third UDS, for which I made the following code :-
#include "udf.h"
#include "math.h"
enum
teg4,
N_REQUIRED_UDS
real k_function(real T)
return -1.097 + 1.234e-2*T - 3.736e-5*pow(T,2.) + 3.75e-8*pow(T,3.);
real rho_function(real T)
return -3.982e-5 + 2.98e-7*T - 4.685*e-10*pow(T,2.) + 2.51e-12*pow(T,3.)
DEFINE_DIFFUSIVITY(teg4_diffusivity, cell, thread, i)
C_UDSI(c,t,teg4) = k_function(C_T(c,t));
return C_UDSI(c,t,teg4);
DEFINE_SOURCE(energy_source, c, t, dS, eqn)
dS[eqn] = C_UDSI(c,t,teg2)*(T/rho_function(C_T(c,t)))*C_UDSI(c,t,teg);
return C_UDSI_G(c,t,teg2)*(T/rho_function(C_T(c,t)))*C_UDSI_G(c,t,teg);
I am getting errors like teg, teg2 not declared.
Can anyone suggest whether the code is wrong or there is some other way to do it?
sahoo is offline   Reply With Quote
Old   June 18, 2018, 20:15
`e`
`e` is on a distinguished road
Because you have not declared these variables. Add these entries to the enum:
enum
	teg,
	teg1,
	teg4,
	N_REQUIRED_UDS
Note that this replaces "teg" with "0", "teg1" with "1" and "teg4" with "2", such that C_UDSI(c,t,teg4) calls the cell value of the third UDS defined.
As previously suggested, perhaps write out the equations you are trying to solve in full and compare these with the UDS transport equations in Fluent. Explicitly, start with writing out the equations you are solving for in each spatial direction (considering the variables are vectors with gradients). Next, find the transport equations used by Fluent for the UDS in the theory guide (note: they are scalars, not vectors). Lastly, match these two sets of equations and determine which scalar terms are appropriate for allocating to UDS.
`e` is offline   Reply With Quote
Old   June 19, 2018, 04:40
Animesh Sahoo
Thanks for your advice, I am going to follow the procedure as described by you.
Mass transfer UDS between two phases rarnaunot FLUENT 1 June 25, 2018 08:22
Can you explain me how to use UDS? Tleja Fluent UDF and Scheme Programming 0 July 14, 2015 02:52
Set UDS on wall... fivos Fluent UDF and Scheme Programming 2 July 25, 2014 06:57
Calculate UDS flux through the wall ananth_01 FLUENT 0 August 5, 2013 08:33
Doubts UDS Flux, UDS Unsteady for VOF model kel85uk FLUENT 0 March 17, 2010 09:53
