Problem using UDF for velocity inlet
Old   June 12, 2018, 10:10
Default Problem using UDF for velocity inlet
panasonic18 is on a distinguished road
Hey,
i've real big problem using an UDF for velocity inlet and can't solve it. It's a Mesh over an Airfoil created with ANSYS ICEM 15.0. When i load the Mesh into FLUENT 15.0 everything is fine, no errors.
Hybrid Initialisation is well without using the UDF, so no Errors without using the UDF.
But when i want to implement the UDF and press Hybrid Initialisation, FLUENT says this:
Error: %prf-set-var: invalid flonum
Error Object: -1.#ind
I can't figure out, where the problem is. Also never heard this error before and searching via google wasn't succesfull. So maybe someone coul help me? Here my defined UDF:
#include "udf.h"
#define c_max 30.88 // unit m/s
#define delta 0.04
DEFINE_PROFILE(inlet_velocity, t, i)
real x[3];
real y;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
y = x[2];
if(x[2] <delta)
F_PROFILE(f,t,i) = c_max * pow(x[2]/delta, 0.2);
else
F_PROFILE(f,t,i) = c_max;
end_f_loop(f,t)
I appreciate every kind of help.
Best regards
panasonic18 is offline   Reply With Quote
Old   June 12, 2018, 22:55
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Dear panasonic18
I think there are mistakes. You define real x[3] but you do not use x[3] in your whole code. you have already written y = x[2] so I think no need to write again x[2] in if(x[2] <delta). Just write if(y <delta). The same case can be applied also in pow(x[2]/delta, 0.2).
For the comment in
you should write
#define c_max 30.88 /* unit m/s */
Hope it helps
Now Or Never!!!
teguhtf is offline   Reply With Quote
Old   June 13, 2018, 03:59
pakk will become famous soon enough
The line with x[3] is correct, don't change it to x[2]. It signals that x is a three-dimensional array. Better is to change it to x[ND_ND].
I think the real problem (apart from the comment-problem after #define) is that you might take a non-integer exponent of a negative number
If you have a cell with negative y-coordinate, for example y=-0.04, then you calculate:
pow(-1, 0.2)
A negative number to a non-integer exponent results generally speaking in a complex result. C does not handle this, and gives an error. Here, because 0.2=1/5, it happens to mathematically give a real result, but still you get an error.
If this is really what you want, then you should help the compiler:
if (x[2]<0) {
  F_PROFILE(f,t,i) = -c_max * pow(-x[2]/delta, 0.2);
} else {
pakk is offline   Reply With Quote
UDF problem- time dependent temperature at inlet kaeran FLUENT 1 June 16, 2015 22:48
Open channel (inlet problem) burak_ekmekci Main CFD Forum 0 December 22, 2014 08:45
UDF profile: Fluent method for coupling inlet and outlet I-mech Fluent UDF and Scheme Programming 0 May 10, 2014 11:36
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 12:21
UDF 3D inlet b.c. problem Andrew FLUENT 4 May 25, 2004 05:24
