"fatal signal (Segmentation fault)" error
Old   June 12, 2018, 10:08
Default "fatal signal (Segmentation fault)" error
hamid
abdihamid is on a distinguished road
Hi `e` i am writing a udf code to define a mixture density that related to uds but when i want to initialize the solution this error appears: received a fatal signal (Segmentation fault)
here is my code:
#include "udf.h"
DEFINE_PROPERTY(cell_density,cell,thread)
Thread *t;
cell_t c;
real c_h2,c_n2,rh2,rn2,rmix=1,c_mix ;
c_h2 = C_UDSI(c,t,0);
c_n2=40.46-c_h2;
rh2=c_h2*2;
rn2=c_n2*28;
rmix=rh2+rn2;
return rmix/1000;
how can i solve the problem help me please
abdihamid is offline   Reply With Quote
Old   June 12, 2018, 10:37
annan
annan is on a distinguished road
Dear abdihamid,
Segmentation fault means you are trying to access something that is not defined.
I can’t understand why you define the thread and cell inside your udf, these two are already given by the DEFINE_PROPERTY macro. I’d suggest you try to remove the lines : “Thread *t; cell_t c;” and replace DEFINE_PROPERTY(cell_density,cell,thread) by DEFINE_PROPERTY(cell_density,c,t)
Hope this will help.
Good luck
Annan
annan is offline   Reply With Quote
Old   June 12, 2018, 11:43
hamid
Dear annan thank you for your help. I apply the changes you suggested but the error still reamins. i dont know how to solve it.
Old   June 13, 2018, 21:43
`e`
`e` is on a distinguished road
Have you added at least one UDS to your model? Otherwise, debug your code by determining which line is causing the error.
This step also needs to be completed because your UDF is calling C_UDSI on the declared variables t and c, but they do not have any values.
`e` is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
