How to solve parse error error in UDF fluent for #DEFINE_INIT?
Old   June 10, 2018, 22:48
Default How to solve parse error error in UDF fluent for #DEFINE_INIT?
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Dear all,
I am new in UDF. I am trying to make different initial guess of temperature distribution in solid by using #DEFINE_INIT CODE in Fluent 17.2. I took the whole code from UDF Fluent Customization sample. I just make little modification. The case is 2D and the solid is in y- direction.
Do you have any advice?
However when the code is interpreted the error shows
Error: E:/profile_temp.c: line 8: parse error.
Thank you for your help
Here is my code
UDF for initializing flow field variables
#include "udf.h"
#define d 5
DEFINE_INIT(temp_prof_init,d)
cell_t c;
Thread *t;
real xc[ND_ND];
/* loop over all cell threads in the domain */
thread_loop_c(t,d)
/* loop over all cells */
begin_c_loop_all(c,t)
C_CENTROID(xc,c,t);
y = xc[1]
if (y < 0) /* y < 0 */
C_T(c,t) = 10.578*y +302.26;
else if (y <-5 )
C_T(c,t) = 4.6277*y + 300.46; /* y < -5 */
else
C_T(c,t) = 290;
end_c_loop_all(c,t)
Now Or Never!!!
teguhtf is offline   Reply With Quote
Old   June 11, 2018, 12:32
obscureed is on a distinguished road
Hi Teguh,
Out of paranoia, I recommend you delete the blank line after the DEFINE_INIT line.
However, the problem is the "#define d 5" -- as you probably know, this is a preprocessor directive. It is basically a "find and replace". I am not sure what you intended this to achieve, but the result is that "DEFINE_INIT(my_init_func,d)" becomes "DEFINE_INIT(my_init_func,5)", which is not valid. Fluent needs a variable name d (and arranges for it to have type Domain*).
Good luck!
Ed
obscureed is offline   Reply With Quote
Old   June 13, 2018, 00:31
Default How to make DEFINE_INIT works only in solid zone?
teguhtf's Avatar
teguh hady
Dear obscureed,
Thank you for your suggestion. I have repaired the code. It works if the only one zone. Actually, I have two zones (Solid and Liquid zone). If I do not define zone ID the initial temperature of solid and fluid will be same. I attach the inital temperature and zone ID (Zone ID 4 is solid and zone ID -1 is liquid. I want to make the DEFINE_INIT works only in solid zone. What should I do for this problem?
Here is my new code
#include "udf.h"
DEFINE_INIT(my_init_func,domain)
cell_t c;
Thread *t;
real xc[ND_ND];
real y;
thread_loop_c(t,domain)
C_CENTROID(xc,c,t);
y = xc[1];
if ( y >= -0.293) /* 12-13 */
C_T(c,t) = 300;
else if ( y >= -0.984) /* 12-13 */
C_T(c,t) = 290;
else if ( y >= -2.992) /* 12-13 */
C_T(c,t) = 280;
else if ( y >= -9.98) /* 12-13 */
C_T(c,t) = 270;
else
C_T(c,t) = 260;
end_c_loop_all(c,t)
Now Or Never!!!
Old   June 13, 2018, 05:56
Hi Teguh,
In UDFs, a "thread" is a cell zone or a face zone. (This becomes more complicated in multiphase models, but it will be OK for now.) So you are asking about how to find a specific thread, based on its ID number. For this, you do not want "thread_loop_c(t,domain){ /*... use t ...*/ }", which repeatedly evaluates the contents with each possible cell thread in t. Instead you want
t = Lookup_Thread(domain, 4);
/*... use t ...*/
By the way, a negative value for a cell ID would be very surprising to me. Please could you check this? Is it different after a mesh check and/or initialization?
Good luck!
Ed
Old   June 18, 2018, 09:14
teguhtf's Avatar
teguh hady
Dear obscureed,
Thank you for your advice. It works good on several time. But, in the initial condition contour, fluent makes the same temperature field in every threat. How to solve that?
Best regards
Now Or Never!!!
Old   June 18, 2018, 10:56
Hi Teguh,
I do not completely understand your question, but it sounds like you need to debug your own UDF code.
Good luck!
Ed
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle FelixJJ FLUENT 2 October 20, 2021 03:39
line 1 parse error UDF Fluent violethill Fluent UDF and Scheme Programming 1 February 25, 2018 22:01
UDF code help solve reaction rate equation palm oil zirkov Fluent UDF and Scheme Programming 0 February 13, 2017 11:34
write code UDF Fluent solve kinetic reaction rate equation palm oil zirkov FLUENT 0 February 13, 2017 11:16
fluent udf problem: write specific data for every iteration in a file. nnvoro Fluent UDF and Scheme Programming 1 May 27, 2013 16:26
