Isotropic Difusivity
Old   June 10, 2018, 09:55
Default Isotropic Difusivity
Anomymous
Nishant_Sharma is on a distinguished road
Hi all,
I have a small doubt, weather the fluent take the user defined diffusivity defined through UDF as isotropic by default or we have to specify it manually.
Thank you
Nishant_Sharma is offline   Reply With Quote
Old   June 11, 2018, 12:25
obscureed is on a distinguished road
Hi Nishant_Sharma,
I think it will become clearer when you try it. The answer might depend on whether you are talking about diffusivity of species or User-Defined Scalars (UDS), but in general isotropic is the default. For species, anisotropic diffusion can only occur in a porous zone, for some reason, and I'm not sure what UDF hooks exist there. For UDS, a different UDF type is required for anisotropic.
By the way, the numerics of anisotropic diffusion/conduction (for example, sensitivity to mesh quality) are significantly more troublesome than isotropic, so you should stick with isotropic if you possibly can.
Good luck!
Ed
obscureed is offline   Reply With Quote
Old   June 14, 2018, 02:27
Anomymous
Thanks obscureed for your reply , it was really helpfull.
difference between isotropic and homogeneous in turbulence dut_thinker Main CFD Forum 11 January 23, 2021 12:11
Compressible Isotropic Turbulence Lokanayaki Main CFD Forum 0 December 23, 2012 10:21
help on isotropic turbulence initial condition Hall Main CFD Forum 8 April 28, 2011 17:55
DNS of isotropic turbulence cfdbuddy Main CFD Forum 0 June 27, 2008 03:45
Help needed on homogeneous isotropic turbulence an Guoping Xia Main CFD Forum 0 March 12, 2006 22:54
