May 31, 2018, 06:13 |
udf to give temperature profile for a plane
Sai Krishna
Rep Power: 8 |
i have tried one code to give temperature variation from 500 to 800 kelvin along z direction for a wall in XZ plane. interpretation and compilation were done without errors but during post processing the temperature results, i didn't observe any variation and its showing 500K all over the plane. presently iam using ansys 18.2 version.
code is as follows. #include"udf.h" DEFINE_PROFILE(temperature,thread,position) { real x[ND_ND]; //defining position vector// real z; face_t f; begin_f_loop(f,thread) { F_CENTROID(x,f,thread) z=x[2]; F_PROFILE(f,thread,position)=500+3*(z); } end_f_loop(f,thread) } my doubts are: 1. is there anything wrong in the code....? 2. does the way of defining the position vector is same for 2D and 3D models? 3. during interpretation do i need to use command name as "cpp" or "cc -E"? 4. does this code works for 3D cases, since i have seen many examples where 2D cases have used this code... any help will be greatly appreciated.... thanks... |
June 1, 2018, 11:05 |
Rep Power: 12 |
Hi Sai Krishna,
1. You need a semicolon at the end of the line containing F_CENTROID. I am surprised that this compiled without errors. 2. Yes, the F_CENTROID command (and many others) are the same in 2D and 3D. It would not be safe to access x[2] in 2D, but this is correct in 3D. 3. I would not recommend interpretation at all. 4. This should be OK in 3D. One issue with your code is probably the formula "500+3*(z)". The units of z are [metre], so you would need a domain size of 100m to reach 800K. This is possible, but you should check whether this is correct for your case. Good luck! Ed |
fluent - udf |
Using a Plane id in Fluent UDF | cdf_user | Fluent UDF and Scheme Programming | 13 | October 17, 2023 01:06 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
Read profile file from UDF | DonQuijote | Fluent UDF and Scheme Programming | 0 | February 18, 2013 12:56 |
Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 07:08 |
Associating profile files for the UDS though a UDF | Bharath | FLUENT | 0 | December 1, 2006 16:58 |
