Boundary condition for alternating material inflow
Old   May 24, 2018, 11:50
Default Boundary condition for alternating material inflow
MAR
mar713 is on a distinguished road
I want to have an inflow of two materials through the same inlet however, alternately rather than simultaneously.
The model being used is Multiphase - Volume of Fluid.
The velocity of the mixture will be fixed while the volume fraction for each material would be continously and alternatingly switched from 1 to 0 and vice versa, so as to simulate slug flow with slugs of defined lengths.
These lengths would obviously depend on the switching times, which in turn would be a function of the mixture velocity and the time step size.
From what I have read, it seems that I need to write a User Defined Function to change the boundary condition continuously during the calculation. My first question is whether or not this approach would be correct.
Additionally, I understand that I could use two inlets instead of a single inlet but, a changing boundary condition would certainly save me a lot of time.
If UDF is the way to go, I believe that I would need to call the volume fraction, the mixture velocity, and the time step size in my UDF. I do not understand how to reference these variables in C. Would anyone be kind enough to point me in the right direction?
I would like to thank you in advance.
Best regards,
MAR
mar713 is offline   Reply With Quote
Old   May 24, 2018, 13:56
zobekenobe
zobekenobe is on a distinguished road
Hi Mar,
You can use the FLUENT udf manual
You mainly have to use the defined the macros to interact with the conditions for your domain.
the DEFINE_PROFILE macro should allow you to define the boundary conditions on whichever boundary you specify to apply it.
CURRENT_TIME is the fluent special macro that would allow you use the flow time to give a periodic boundary condition for different inlet conditions.
there are multiphase macros which you can then explore to access each phase and their volume fraction
I hope this helps you get started
cheers!!
zobekenobe is offline   Reply With Quote
boundary condition, fluent - udf, vof multiphase
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
