May 24, 2018, 05:33 |
get-surface in string list
DS
Rep Power: 10 |
Goodmorning,
I need to save in a string-list the name and id of all surfaces created in fluent. I did the same with the threads and works as written in the following code, but I don't know how to do the same with the surfaces. I tried with (get-surfaces) but without success. I would ask if someone know how to do that. HTML Code:
(rp-var-define 'a () 'string-list #f) (rpsetvar 'a ()) (for-each (lambda (t) (rpsetvar 'a (list-add (rpgetvar 'a) (thread-name t)))) (get-all-threads)) (rpgetvar 'a) Best regards Denis |
May 24, 2018, 05:57 |
Rep Power: 12 |
Hi Denis,
I think the Scheme command that you want is Code:
(map symbol->string (inquire-surface-names)) The reason I recommend the (map symbol->string ...) wrapper is that some commands like this return a list of objects/symbols, rather than a list of strings. This can make a big difference -- namely, if you type one of these commands into the Fluent command window, Fluent attempts to display the results, and this can crash the session fatally if the objects are not easy to display. So, save your case before you experiment! Good luck! Ed |
May 24, 2018, 06:35 |
#3 | |
DS
Rep Power: 10 |
Thank you Best Regards Denis |
get-surfaces list string |
SU2 cfg file and runtime problems | hedley | SU2 | 19 | January 26, 2016 05:17 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 16:03 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 13:43 |
