HELP with FATAl error
Old   May 23, 2018, 10:09
Default HELP with FATAl error
Mahdev Prasad Panda
Mahadev is on a distinguished road
Hy
I am using the following code to define density as a function of pressure and temperature but I am getting fatal error and when I am using parallel processing fluent could not even interpret it as the fluent window shuts down.
Please help me with it. Thanks in advance.
#include "udf.h"
DEFINE_PROPERTY(superfluid_density, c, t)
double rho;
double p, temp;
p = C_P(c,t) ;
temp = C_T(c,t);
rho = (12.19)-(0.0398*temp)+(0.00003551*p);
return rho;
Mahadev is offline   Reply With Quote
Old   May 23, 2018, 11:05
obscureed is on a distinguished road
Hi Mahadev,
The help files say: "In order to stabilize the pressure solution for compressible flows in ANSYS Fluent, an extra term related to the speed of sound is needed in the pressure correction equation. Consequently, when you want to define a custom density function for a compressible flow, your model must also include a speed of sound function."
Also, you might want to look at the effect of the Operating Pressure. Depending on that, and what is going on in your model, your equation for density could easily go negative. That will not end well.
It would be a good idea to get warmed up with only temperature dependence, not pressure dependence. If the model does not absolutely need pressure-dependent density, then it will save trouble to neglect it.
Good luck!
Ed
obscureed is offline   Reply With Quote
Old   May 23, 2018, 12:15
Mahdev Prasad Panda
Thank you for replying me.
Do I have to include the speed of sound in the density function or it should be given separately in the speed of sound section???
Old   May 23, 2018, 13:08
Hi Mahadev,
Please consult the help files.
Best regards,
Ed
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 01:10
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
