How to write UDF for the density at melting point?
Old   May 22, 2018, 04:49
Default How to write UDF for the density at melting point?
Shivam Kumar
smkr is on a distinguished road
I am modelling isothermal melting of the metals in FLUENT 17.2. I am unable to give different density for the solid and liquid at the melting point. Can any one please tell me about how to write an UDF for this.
Thank You!
smkr is offline   Reply With Quote
Old   May 23, 2018, 07:54
zobekenobe
zobekenobe is on a distinguished road
using define_property you can select the material and then in it's density tab hook the following macro
define the melting point and the solid and liquid density, and using an if else assign the required density and return it from the macro
#define "udf.h"
#define T_melting_point = 100;
#define solid_density = 10.0;
#define liquid_density = 2.0;
DEFINE_PROPERTY(udf_name, c, ct)
    real temp = C_T(c, ct);
    real metal_density;
    if(temp > T_melting_point)
        metal_density = liquid_density;
    else
        metal_density = solid_density;
    return metal_density
hope this helps
zobekenobe is offline   Reply With Quote
Old   May 23, 2018, 21:47
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
fluent has "solidification & melting" model
use Ansys Fluent User's Guide and Ansys Fluent Tutorial Guide to find detailed information
best regards
AlexanderZ is offline   Reply With Quote
confusion on how to write udf for density of a mixture solution in multiphase problem Hirakjyoti Fluent UDF and Scheme Programming 1 September 11, 2017 02:21
Can we write UDF for secondary phase droplet/bubble diameter in Eulerain model? Navier Stoke Fluent UDF and Scheme Programming 1 September 7, 2017 16:02
Point Source for Radiation by UDF daire6 FLUENT 0 May 13, 2016 09:07
[ICEM] Point density as a custom function/spline (Pre-Mesh Params)? Electrophile ANSYS Meshing & Geometry 1 July 21, 2015 09:03
UDF for searching the closest point to a certain point princekar Fluent UDF and Scheme Programming 2 April 26, 2015 05:53
