UDF interpreted Error
Old   May 11, 2018, 03:25
Default UDF interpreted Error
ctmagic is on a distinguished road
Hi, Eeverybody!
I'm using fluent 17.
my udf is as bellowacturally, it's partly copied from the Ansys help)
#include "udf.h";
#inclue "math.h";
DEFINE_VR_RATE(reforming_rate,c,t,re,mw,yi,rr,rr_t )
if (!strcmp(re->name, "reaction-1")) -----line 49
*rr=r1v
else if (!strcmp(re->name, "reaction-2"))
*rr=r2v
else if (!strcmp(re->name, "reaction-3"))
*rr=r3v
else
/* Message("Unknown Reaction\n"); */
when the UDF is interpreted in fluent, a error ( line 49:structure reference not implemented) occured.
Is there any parse error? Or should I include more head files?
Many thanks in advance!
ctmagic is offline   Reply With Quote
Old   May 11, 2018, 05:36
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
was
*rr=r1v
new
*rr=r1v;
may be this one? On the other hand, problem comes from lines above #49, check what is inside your ...
best regards
AlexanderZ is offline   Reply With Quote
Old   May 11, 2018, 21:28
Missing of symbol ";" is another obvious error, thanks a lot!
However,i'm afraid that the problem mentioned in my post is about the variable "r", which is defined by fluent macro.
I have tried to used the example udf in fluent help, the error still occured"structure reference not implemented".
it make me crazy.Could you please tell me why? Many thanks!
the example udf from fluent helps is as below:
#include "udf.h"
DEFINE_VR_RATE(myrate,c,t,r,mw,yi,rr,rr_t)
/*If more than one reaction is defined, it is necessary to distinguish
between these using the names of the reactions. */
if (!strcmp(r->name, "reaction-1"))
/* Reaction 1 */
else if (!strcmp(r->name, "reaction-2"))
/* Reaction 2 */
else
/* Message("Actual Reaction: %s\n",r->name); */
Originally Posted by AlexanderZ View Post
was
*rr=r1v
new
*rr=r1v;
best regards
Old   May 13, 2018, 22:22
Alexander
Use compile instead of interpretation
best regards
Old   May 14, 2018, 23:26
Hi, AlexanderZ!Thanks, it works!
best regards
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 07:25
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 07:45
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 19:54
