Problem programming UDF
Old   May 9, 2018, 04:32
Default Problem programming UDF
Víctor Rueda García
victorueda7 is on a distinguished road
Good morning, I'm trying to program an UDF for viscosity. I have this code:
#include "udf.h"
DEFINE_PROPERTY(custom_viscosity, c, t)
double visco;
double gamma=C_STRAIN_RATE_MAG(c,t);
visco=75/gamma+0.042;
return visco;
But, starting to run the calculation, Fluent shows the next message:
"Divergence detected in AMG solver: x-momentum"
Does anybody knows which is the problem with the code?
Thank u very much.
victorueda7 is offline   Reply With Quote
Old   May 11, 2018, 15:36
mohamed
moh_zain is on a distinguished road
Hi if the calculation start and then stop it may be from the mesh quality or solution method you use( focus on mesh quality first )
moh_zain is offline   Reply With Quote
Old   May 12, 2018, 14:47
pakk will become famous soon enough
Hint: what happens if the strain rate is zero?
pakk is offline   Reply With Quote
Old   May 16, 2018, 12:38
Víctor Rueda García
Thank u moh_zain, but the problem is that I'm simulating a function that is already in the database as "Herschel Bulkley" model, so, if the simulation works with the default "Herschel Bulkley" function, it should be the same with my UDF
Old   May 16, 2018, 12:41
Víctor Rueda García
Thank u pakk, the problem is that this UDF function is supposed to return the same values as the "Herschel Bulkley" default function, that I have already tried with the same configuration (mesh...). So, I guess the problem is I don't know how to use the "Shear rate" variable, could u help me?
Thank u very much again.
Old   May 17, 2018, 03:02
No, your problem is in the physics.
The equation that you give is only valid if the strain rate is larger than the strain rate threshold. For low strain rates (and strain rate = 0 is low), a different equation holds.
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
Vaporization pressure UDF property problem? lehoanganh07 Fluent UDF and Scheme Programming 1 September 13, 2014 11:59
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 07:56
problem with udf programming in fluent saranyasimi Main CFD Forum 0 December 1, 2009 13:19
