How to define an axis in UDF?
Old   May 8, 2018, 12:16
Default How to define an axis in UDF?
Larrabee is on a distinguished road
Hi, everyone. I am now working on a problem about a pitching 2D airfoil. I have written my UDF and it makes the airfoil oscillate. However, the airfoil is now oscillating around Z axis and I want to set the axis to be 1/4 of the chord length. What should I do to the UDF?
#include "udf.h"
#define Freq 2.0
#define w 2.0*M_PI*Freq
#define pitch 7.5*M_PI/180
DEFINE_CG_MOTION(shm, dt, cg_vel, omega, time, dtime)
real omega;
omega = pitch*w*cos(w*time);
cg_vel[0] = 0.0;
cg_vel[1] = 0.0;
cg_vel[2] = 0.0;
cg_omega[0] = 0.0;
cg_omega[1] = 0.0;
cg_omega[2] = omega;
Larrabee is offline   Reply With Quote
Old   May 8, 2018, 22:27
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
cg_omega[0] = 0.0;
cg_omega[1] = 0.0;
cg_omega[0] means omega across x axis, cg_omega[1] - across y axis, cg_omega[2] - across z axis
if you want some "mix" axis you should find normalized vector your axis you want and put it here, for instance for vector {1,1,1}:
cg_omega[0] = 1*omega;
cg_omega[1] = 1*omega;
cg_omega[2] = 1*omega;
best regards
AlexanderZ is offline   Reply With Quote
Old   May 9, 2018, 05:44
But, the rotating axis is still across the origin. I want to set the axis to be ,say line x=1, and rotate at omega_z=1.
Old   May 14, 2018, 11:15
obscureed is on a distinguished road
Hi Larrabee,
If you combine rotation about the origin with a translational velocity that keeps the axis-point stationary, then you get rotation about the axis-point.
You could also consider shifting the entire geometry until your axis *is* the origin.
Good luck!
Ed
obscureed is offline   Reply With Quote
Old   July 23, 2018, 01:11
Hanye Azimi
ronak is on a distinguished road
#include "udf.h"
#define Freq 2.0
real omega;
cg_vel[0] = 0.0;
cg_vel[1] = 0.0;
cg_vel[2] = 0.0;
cg_omega[0] = 0.0;
cg_omega[1] = 0.0;
You are simulating a pitching motion in Fluent,yeah?
you could define the pitching axis in Fluent in this way :
Cell Zone Conditions , rotation-axis origin , x=0.25(if Leading Edge is at 0,0)
you may define this point (0.25*chord length) as the centre of gravity location,too.
ronak is offline   Reply With Quote
Old   July 23, 2018, 01:21
Hanye Azimi
I'm working on a similar case. It's been validated while angle of attack equals zero but the results doesn't match when there is A.O.A and I don't know how to input Alpha(angle of attack) in the UDF
my UDF is:
#include "udf.h"
#define pi 3.141592653589793 //
DEFINE_CG_MOTION(airfoil_pitch, dt, vel, omega, time, dtime)
real pitchampl,omg,frequency;
/* reset velocities */
NV_S (vel, =, 0.0);
NV_S (omega, =, 0.0);
/* motion */
frequency=0.06;
omg=2*pi*frequenc;
pitchampl = 15 * pi / 180; /* angular pitch amplitude */
omega[2] = pitchampl *omg* cos(omg * time);
Hydrogen storage by metal hydride longbk FLUENT 12 August 1, 2023 21:13
Help! DMFC UDF problems Biao FLUENT 1 November 2, 2020 08:39
An odd ERROR mdakbari Fluent UDF and Scheme Programming 7 April 4, 2016 05:30
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
Help: using udf to define direction Bo FLUENT 1 July 16, 2008 07:47
