May 7, 2018, 02:33 |
Mean Age of Air
payam
Rep Power: 13 |
Dear All member
I have problem to define mean age of air as a new scalar in fluent particularly about the boundary condition definition. So any help is highly appreciated. |
May 7, 2018, 03:24 |
Rep Power: 26 |
If you want help with your problem, you have to explain what your problem is.
May 7, 2018, 03:37 |
payam
Rep Power: 13 |
In simple word, my model has a room with two windows (one as the opening and other as the exit of the air). when I want to define the boundary conditions, I should define the scalar of (mean age of air) as 0 in the opening. But the problem is in the inlet and outlet of the domain, also the scalar is defined as 0 which is not correct (only for the opening should be zero).
Thank you very much |
May 7, 2018, 03:43 |
Rep Power: 26 |
I am already confused why you think this should be a scalar (by which I assume you mean UDS, User-Defined Scalar).
May 7, 2018, 04:01 |
payam
Rep Power: 13 |
yes, you are right it is user defined scalar.
May 7, 2018, 06:27 |
Rep Power: 26 |
And I don't understand how "mean age of air" can have the properties that a UDS has. What would diffusion of a mean age even mean? It makes no sense.
You are using the wrong tool for this job. You probably want to know how long a 'molecule' has been in your simulation domain. Which is an interesting question, not easy to answer but certainly doable. But a UDS is not the right tool for that. My idea would be to use a UDM to store the information, and use a UDF to fill the UDM. Alternatively, it might be possible to use a custom field function to calculate this. The difficult part is to write a UDF to fill the UDM. It is certainly possible, but it would take me too much time to do for free on this forum. |
mean age of air |
Natural Convection Air Temperature Problem | theBerNii | FLUENT | 1 | November 28, 2016 13:30 |
Air entrainment model setup for spillway | oajor | FLOW-3D | 4 | November 17, 2016 12:02 |
CFD analysis on wind turbine rotor | Ken (Wind Turbine CFD Super Rookie) | Main CFD Forum | 45 | February 9, 2016 14:07 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
[Indoor Air Quality]How do I calcauate "Age of Air | Young | CFX | 6 | April 28, 2008 23:14 |
