UDF For Source term
Old   May 6, 2018, 16:22
Default UDF For Source term
Priyank
Priyank Mehta is on a distinguished road
Hello
I want to increase the temperature of a specific part in my geometry so for that I am using 2 things
1. I am creating 2 zones.(flow zone and source zone (Random names are given))
2. Using udf (for source term) and hook it to source zone.
from this, I am achieving my goal.
this is working properly as I want to increase my temperature from 300 to 2500 in few time steps (it will be like a spark)
Now the problem is as my temperature is increasing and I kept density to be constant....my pressure is not changing (1 atm).
My system is closed vessel.
Temperature increase and density are constant ---> then pressure should increase in a specific part.
SO can you please explain why it is happing.
Or any other way is there to increase a temperature od certain region for certain time.
I hope you understand
Thank you
Priyank Mehta is offline   Reply With Quote
UDF to visualize the cavitation source term: getting a very strange result!!! dinhanh Fluent UDF and Scheme Programming 1 June 6, 2015 11:29
UDF for momentum source term Tanmay_Dutta Fluent UDF and Scheme Programming 0 December 6, 2014 07:24
UDF sink term pichai FLUENT 0 October 20, 2010 02:07
UDF Source Term Christian FLUENT 4 August 1, 2009 06:53
UDF Source Term Units? Brian FLUENT 1 October 24, 2005 10:15
