UDF debugging - Setting breakpoints in Windows
Old   May 2, 2018, 12:48
Default UDF debugging - Setting breakpoints in Windows
msw
Marvin
msw is on a distinguished road
Hello
Im working on a rather large UDF code in VS2017.
In general, my code seems fine, there are just some logic errors. I am looking for a way to go through the code by setting breakpoints, hence, stop fluent at these points to check the values.
I found this manual to setup gdb but it only seems to work on linux:
https://www.cfd-online.com/Wiki/Udf_debug
I am outputting values by file and message command, but setting breakpoints would be a lot more helpful. I heard its possible with VS?
Thank you in advance!
msw is offline   Reply With Quote
2018, ansys, debug, fluent, udf
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
UDF - Debugging techniques PK FLUENT 2 February 6, 2007 17:44
Debugging 3d parabolic udf david FLUENT 4 June 13, 2005 15:20
