Multiphase UDF problem
Old   May 1, 2018, 19:01
Default Multiphase UDF problem
Lukas
Sijnhaven is on a distinguished road
I am simulating liquid-gas muliphase flow.
I need a UDF to define the bubble diameter for the gas phase.
I can interpret the UDF, but after initialization I get this error message:
"Node X: Process 11780: Received signal SIGSEGV"
Something is going wrong in the part of the code that is calling the properties of the primary and secondary phases.
Thank you for responding.
UDF:
#include "udf.h"
DEFINE_PROPERTY(BubbleDiameter, c, mixture_thread)
real BD; /* Bubble diameter */
int SurfaceTension;
int PhaseOneIndex = 0;
int PhaseTwoIndex = 1;
real DensS; /* S = primary (liquid) phase */
real DensG; /* G = secondary (gas) phase */
real XVelS;
real XVelG;
real YVelS;
real YVelG;
real ZVelS;
real ZVelG;
real EffViscG;
Thread *p1 = THREAD_SUB_THREAD(mixture_thread,PhaseOneIndex);
Thread *p2 = THREAD_SUB_THREAD(mixture_thread,PhaseTwoIndex);
DensS = C_R(c,p1); /* density liquid */
DensG = C_R(c,p2); /* density gas */
XVelS = C_U(c,p1); /* x velocity liquid */
XVelG = C_U(c,p2); /* x velocity gas */
YVelS = C_V(c,p1); /* y velocity liquid */
YVelG = C_V(c,p2); /* y velocity gas */
ZVelS = C_W(c,p1); /* z velocity liquid */
ZVelG = C_W(c,p2); /* z velocity gas */
EffViscG = C_MU_EFF(c,p1); /* effective viscosity of the gas phase */
SurfaceTension = 1.76;
BD = XXX ; /* HERE WILL BE MY FORMULA */
return BD;
Sijnhaven is offline   Reply With Quote
Old   May 2, 2018, 13:27
Star
sikandar is on a distinguished road
UDF:
#include "udf.h"
int SurfaceTension;
real XVelS;
real XVelG;
real YVelS;
real YVelG;
real ZVelS;
real ZVelG;
real EffViscG;
return BD;
did you found the solution of this matter? Do you have UDF for terminal Velocity of bubble i need help
sikandar is offline   Reply With Quote
Old   May 2, 2018, 20:51
Lukas
Yes, I believe the DEFINE_PROPERTY macro does not pass the mixture_thread, because it is coupled to the bubble diameter, which is a secondary (gas) phase property. So in this case, the DEFINE_PROPERTY macro passes the thread of the secondary phase.
The solution that I found was to first look up the mixture_thread with THREAD_SUPER_THREAD(p2), in which p2 is the thread of the secondary phase, that was passed by the solver through the DEFINE_PROPERTY macro.
Then, in a next step, I define the thread of the primary phase by using the macro THREAD_SUB_THREAD(mixture_thread,0). Of course, it is not needed to explicitly lookup the thread of the secondary phase with THREAD_SUB_THREAD(mixture_thread,1), because it was already passed to the UDF by the solver.
Unfortunately, I do not have a UDF for terminal velocity. I never used this.
Regards
Old   May 8, 2018, 11:59
tahir
ENGRTAHIR is on a distinguished road
Hi i also need help for bubble diameter. I am doing two phase simulation in fluent with combustion
ENGRTAHIR is offline   Reply With Quote
Problem accessing material properties in UDF for Multiphase Multispecies pmtgt Fluent Multiphase 3 January 17, 2021 08:11
Mesh UDF problem kornetka Fluent UDF and Scheme Programming 4 July 25, 2013 07:54
Help! Compiled UDF problem 4 Wave tank tutorial Shane FLUENT 1 September 3, 2010 03:32
UDF using problem, error happens-heip!! Michael FLUENT 1 December 9, 2008 08:51
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 11:22
