How to get the rotate speed in 6DOF simulation?
Old   April 20, 2018, 23:08
Default How to get the rotate speed in 6DOF simulation?
Klxing
jealor is on a distinguished road
Hi everybody
I am using 6DOF to simulation the transient working of a turbin, 6DOF UDF and other settings now seem to work, but I have the problem of getting the varying rotate speed.
I have toggled the checkbox in 6DOF for "Write rotation history", and it writes a file about "time THETA_Z".
At first I thought I can calculate the speed (rpm) using 'THETA_Z' dividing 'time', However, the calclation results seem to be incorrect because the result is not a Continuous curve, but hops up and down between initial speed and a value that is slightly smaller than it
So I was wondering, is there any method that I can record or calculate the rotate speed of the domain?
Thanks very much!
jealor is offline   Reply With Quote
Z-dimension for 2D 6DoF simulation Fieschi OpenFOAM Pre-Processing 1 March 30, 2020 00:01
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 03:28
Simulation of high pressure diesel injector - all phases compressible with cavitation fivos CFX 4 July 30, 2015 07:48
how can I speed up unsteady simulation Avinash_Chandra FLUENT 2 November 6, 2009 02:33
a transient simulation question rystokes CFX 3 June 3, 2009 08:44
