Return the number of cells on one side of the wall
Old   April 16, 2018, 22:32
Default Return the number of cells on one side of the wall
newuser
new_cfd is on a distinguished road
I'm trying to write a program that linearly increases the heat flux on one side of the wall. How do I determine the number of cells in the first column of the mesh? Please do help.
new_cfd is offline   Reply With Quote
Old   April 18, 2018, 04:41
pakk will become famous soon enough
So go to the help, see that there is an example for a parabolic profile, and change it to linear...
#include "udf.h"
DEFINE_PROFILE(lin_incr,t,i) {
 face_t f;
 float x[ND_ND];
 begin_f_loop(f,t) {
  F_CENTROID(x,f,t);
  F_PROFILE(f,t,i) = 213.12512 + 1.135 * x[0];
   /* change the coefficients above to what you need */
 end_loop(f,t);
Why do you want to know this? It has nothing to do with your first question.
pakk is offline   Reply With Quote
Old   April 18, 2018, 20:42
newuser
Thanks a lot.
I thought I would need it to determine the rate of increase.
Old   April 18, 2018, 22:45
Default Error message for code
newuser
Also, how do I linearly increase from 0 to 500?
Old   April 19, 2018, 03:45
Choose the coefficient such that it is 0 on one end and 500 on the other end.
Old   April 19, 2018, 06:38
newuser
I used the code
F_PROFILE(f,t,i) = 0+1.25*x[0]
Will the above work? I aimed to increase from 0 to 500 by increasing each cell by 1.25.
Old   April 19, 2018, 06:43
This will give 0 at x=0m, and 500 at x=400m.
So if you have a 400 meter long boundary, starting at x=0, then it works.
If not, do some (simple) mathematics. You (should) know at which x-position you want zero heat flux, and you (should) know at which x-position you want 500 heat flux. So you have to points, find a line that goes through these two points, write down the equation, and put this equation in your udf.
Old   April 20, 2018, 05:11
newuser
It worked for the right vertical wall. But, for my left vertical wall it did not. I used 0 + 1250 y[0].
Can you tell me what to use for the left one? One time when I tried, the heat flux continued to the bottom portion as well and didn't stop.
Also, how do I know from which cell the centroid calculation starts? From the top most cell or bottom?
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 18:12
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
