DPM Switching doesn't switch law when I have specified
Old   April 11, 2018, 16:39
Default DPM Switching doesn't switch law when I have specified
sunil kumar
skumar112 is on a distinguished road
I have set a DPM switch so that the laws change with a user defined scalar but the laws are not switching when I have specified. Does anyone know why this is
Material *m = TP_MATERIAL(tp);
if (TP_USER_REAL(tp,0) > 0.5)
TP_CURRENT_LAW(tp) = DPM_LAW_USER_1;
if (TP_USER_REAL(tp,0) <= 0.5)
TP_CURRENT_LAW(tp) = DPM_LAW_INITIAL_INERT_HEATING;
skumar112 is offline   Reply With Quote
Old   April 11, 2018, 23:03
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
code looks correct (comparing to example from manual)
did you hook your function in fluent GUI?
you may try to check your condition (TP_USER_REAL(tp,0) > 0.5) using Message function:
DEFINE_DPM_SWITCH(dpm_switch, tp, coupled)
int i=0,j=0;
if i==0 {Message0("in DPM_LAW_USER_1 \n"); i++;}
else {
if j==0 {Message0("DPM_LAW_INITIAL_INERT_HEATING \n "); j++;}
best regards
AlexanderZ is offline   Reply With Quote
Old   April 12, 2018, 04:49
sunil kumar
Yes I have hooked the function in the GUI.
It moves into the heating law as it displays the message but the law is not doing what I am expecting it to do. That was very helpful thank you I will have to give it some further investigation.
Old   April 13, 2018, 04:39
obscureed is on a distinguished road
Hi AlexanderZ,
Is the intention of i and j to get the information messages only once? With your code as suggested, this will not happen, because i and j are initialised to 0 on every visit. To get only one message, you would need to define i and j as static variables outside the UDF:
static int i=0,j=0;
  if (i==0) {Message0("in DPM_LAW_USER_1 \n"); i++;}
}else {
  if (j==0) {Message0("DPM_LAW_INITIAL_INERT_HEATING \n "); j++;}
There is now an issue that you now get one message, even for many particles and many releases. To get the message again, you need to reset i and j, for example by recompiling. This is not an easy area...
Ed
obscureed is offline   Reply With Quote
Old   April 14, 2018, 04:44
Alexander
thank you for comment.
with i and j i wanted to run message function only once.
we may put i and j in DEFINE_EXECUTE_AT_END macros to set i and j = 0 after each time step.
For that case we should define i and j as global variables.
best regards
DPM Switching skumar112 Fluent UDF and Scheme Programming 0 April 4, 2018 13:10
DPM UDF for switching law amilachandra Fluent UDF and Scheme Programming 1 September 15, 2016 04:43
UDF for Drag law in DPM mail.leonardo Fluent Multiphase 1 July 18, 2016 04:41
UDF for DPM Law Switch Leepox Fluent UDF and Scheme Programming 0 August 26, 2013 06:36
questions about the DPM law rookie FLUENT 0 June 16, 2003 12:41
