Error in compiling udf in fluent
Old   April 10, 2018, 15:05
Default Error in compiling udf in fluent
vikash
harshvikash is on a distinguished road
When I am adding my udf file and building it, then this error comes up in fluent's command line:
(system "copy "C:\PROGRA~1\ANSYSI~1\v150\fluent"\fluent15.0.0\sr c\makefile_nt.udf "libudf\win64\3d\makefile" ")
1 file(s) copied.
(chdir "libudf")(chdir "win64\3d")# Generating ud_io1.h
new_udf_at_end.c
C:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\ucrt\corecrt_math.h(4 94): error C2059: syntax error: 'constant'
C:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\ucrt\corecrt_math.h(4 94): error C2143: syntax error: missing ')' before '/'
C:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\ucrt\corecrt_math.h(4 94): error C2143: syntax error: missing '{' before '/'
C:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\ucrt\corecrt_math.h(4 94): error C2059: syntax error: '/'
C:\Program Files (x86)\Windows Kits\10\include\10.0.16299.0\ucrt\corecrt_math.h(4 94): error C2059: syntax error: ')'
Done.
Next when I click on load this message comes up:
Error: The UDF library you are trying to load (libudf) is not compiled for 3d on the current platform (win64).
please help me, how can I use my udf in fluent
harshvikash is offline   Reply With Quote
Old   April 11, 2018, 01:01
Doruk Yelkenci
doruk is on a distinguished road
There are problems with your code. Double check the code for your parenthesizes
doruk is offline   Reply With Quote
Old   April 11, 2018, 11:00
pakk will become famous soon enough
No, this problem is not in your code, it is in math.h.
Your system is not set up properly. There are other threads in this forum that explain how to do this.
pakk is offline   Reply With Quote
fluent - udf
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
How to solve UDF compilation problems in Fluent. pakk Fluent UDF and Scheme Programming 16 September 10, 2018 03:48
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Error while compiling udf in fluent 13.0.0 siddharth12 FLUENT 0 December 3, 2013 17:46
compiling my UDF Seyed Farid Hosseinizadeh FLUENT 22 February 14, 2006 11:19
