Manish Kumar Jaiswal
Rep Power: 0 ![]() |
Hi all,
I am trying to compile a UDF for oscillation but it repeatedly gives the Error: The UDF library you are trying to load (libudf) is not compiled for 2d on the current platform (ntx86). Please help me to get rid of this error, what software compatibilities are required in order to compile a UDF. If anybody can post some thread or online tutorial for UDF compilation starting from geometry level in "ANSYS FLUENT". Thanks, Manish |
Alexander
Rep Power: 34 ![]() ![]() |
you are LOADING instead of compiling. you should click BUILD
for your information https://www.cfd-online.com/Wiki/Fluent_FAQ best regards |
Thanks, AlexanderZ
I have tried the same ie. first I build it and then loaded it, still faced the same difficulty Thanks, Manish |
Rep Power: 26 ![]() |
Click BUILD and look at the text on your screen! Most likely there is an error message.
udf cg motion, udf compilation |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
