Undefined variable
Old   March 29, 2018, 23:53
Post Undefined variable
Zhu
SJTUmoyu is on a distinguished road
Please help me! When I start my UDF program, there is an error "rpgetvar: part/charge-rate: undefined variable". What's wrong with it?
SJTUmoyu is offline   Reply With Quote
Old   March 30, 2018, 00:19
yanghai
yanghai is on a distinguished road
you should talk about your model and what you want to do, and put your udf on. because we know nothing about you want to do.
yanghai is offline   Reply With Quote
Old   March 30, 2018, 00:28
Zhu
Thank you. In dpm model, I want to charge particles.
I should know the charge rate of particles. I used "RP_Get_Real(part/charge-rate)" to get parameter. But when I start my udf program. An error appeared. "rpgetvar: part/charge-rate: undefined variable". So I wonder whether I should define the variable of "part/charge-rate" and how to define it.
Following is my partial udf about "RP_Get_Real".
#include "udf.h"
#include "sg_udms.h"
#include "charge_udf.h"
Domain *fl_domain=NULL;
real epsilon_0=8.854e-12;
real d_charge=0.;
real charge_max=0.;
* Get charge parameters (set via Scheme)
void get_charge_parameters(void)
d_charge=RP_Get_Real("part/charge-rate");
charge_max=RP_Get_Real("part/charge-max");
Old   March 30, 2018, 04:08
yanghai
#include "udf.h"
real d_charge=0.;
real charge_max=0.;
are you sure you can complied the udf successful? there is no DEFINE macro? i know a little about the dpm model.but i think it must have DEFINE macro in any udf. or, part/charge-rate may not is a parameter in fluent, it is why to occur the error.
Old   March 30, 2018, 04:37
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
where did you get this code?
inside your "own" code there is a comment
it tells that rp-vars should be set through scheme
best regards
AlexanderZ is offline   Reply With Quote
Old   March 30, 2018, 06:47
Post
Zhu
yes! I have defined macro. The udf I showed is just a partial udf. The error occurs due to this udf.
Old   March 30, 2018, 06:53
Post
Zhu
best regards
Do you mean that "part/charge-rate" should be defined through scheme?
And can you tell me how to define vars through scheme?
Thank you very much !
Old   March 31, 2018, 12:47
pakk will become famous soon enough
And did you compile (do this!) or interpret (don't do this!)?
pakk is offline   Reply With Quote
Old   April 1, 2018, 22:36
Post
Zhu
Yes,I have compiled it successfully.
rp_get_real
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 05:28
LEMOS InflowGenerator r_gordon OpenFOAM Running, Solving & CFD 103 December 18, 2018 01:58
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
