March 23, 2018, 05:51 |
Reading mesh from variable
Mattias Stridh
I have a very problem which I am sure has a very simple solution but I don't seem to find it. I have a journal file and in that file I read meshes and journals from another folder. I want to make a variable called path to the folder and only add the file name when I do the reading. What I want to do is (define path "/home/.../working_folder/") file/read-mesh (string-append path "my_mesh.msh") file/read-journal (string-append path "my_journal.jou") But read-mesh tries to read (string-append... Same thing if I do (define path "/home/.../working_folder/") (define full_path (string-append path "my_mesh.msh")) file/read-mesh full_path "Error: File "full_path" not found!" I am in a Linux environment. Thanks |
March 25, 2018, 22:50 |
#2 | |
Alexander
Rep Power: 34 |
you may try to use this function Code:
(ti-menu-load-string (format #f "file r-c ~a OK\n" (string-append path "my_mesh.msh"))) |
March 26, 2018, 04:13 |
Mattias Stridh
Great! Thank you
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
[ICEM] Error reading 2D hybrid ICEM mesh into Fluent | Kloz | ANSYS Meshing & Geometry | 1 | June 6, 2016 14:45 |
Cht tutorial in 15 | braennstroem | OpenFOAM Running, Solving & CFD | 197 | June 10, 2015 04:02 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
