Outlet temperature to temperature boundary condition of velocity inlet. (UDF)
Old   March 22, 2018, 08:32
Default Outlet temperature to temperature boundary condition of velocity inlet. (UDF)
dongsu park
dillon is on a distinguished road
Good day Guys.
I have a big problem to give temperature condition in inlet condition.
Simulation is like under.
there is a pipe in sea water. and initial temperature condition of sea water is 277.15K and pipe and fluid are 343.15K.
I want to give outlet temperature to inlet temperature.
like that
time step 1 of outlet temperature to time step 2 of inlet temperature
and
time step 2 of outlet temperature to time step 3 of inlet temperature.
I'm not familiar with c++ code and i think i couldn't make this for myself.
this is code i found and revised....
#include "udf.h"
#define get_temp_zone_ID 26
real Abstemperature =343.15;
DEFINE_ADJUST(find_Abstemperature,domain)
#if !RP_HOST
Thread *ft,*ct;
face_t f;
cell_t c;
/* int ID = 26; */
ft = Lookup_Thread(doamin,get_temp_zone_ID);
ct = THREAD_T0(ft);
begin_f_loop(f,ft)
c = F_C0(f,ft);
if(Abstemperature > C_T(c,ct))
Abstemperature = C_T(c,ct);
end_f_loop(f,ft)
#endif
DEFINE_PROFILE(Abstemperature, t, enq)
face_t f;
begin_f_loop(f, t)
F_PROFILE(f, t, enq) = Abstemperature;
end_f_loop(f, t)
If anyone professional in UDF..
Please help me
Sincerely Dillon.
dillon is offline   Reply With Quote
Old   March 24, 2018, 02:36
Doruk Yelkenci
doruk is on a distinguished road
You cant carry variables between 2 different macros. Just use define profile.
doruk is offline   Reply With Quote
Old   March 24, 2018, 23:51
dongsu park
Thank you for reply doruk.
as you say. I make code using only difine profile like this
#include "udf.h"
DEFINE_PROFILE(temp_in,thread,i)
Domain *d;
real temp_in;
int ID_outlet=26;
face_t f;
Thread *t;
d = Get_Domain(14);
t= Lookup_Thread(d, ID_outlet);
begin_f_loop(f,thread)
temp_in = F_T(f,t);
F_PROFILE(f, thread, i) = temp_in;
end_f_loop(f,thread)
...but it cant work..
when i click 'Initialize' error pops up
massage is "MPI Application rank 0 exited before MPI_Finalize() with status 2
The fl process could not be started."
what should i d?
Old   March 25, 2018, 12:06
Doruk Yelkenci
check your threads. You have defined t= Lookup_Thread(d, ID_outlet) but for the loop you are using begin_f_loop(f,thread).
Change it to begin_f_loop(f,t)
Hope it works now
Best Regards
Doruk
The method on dealing with velocity in static pressure outlet boundary condition mona.li CFX 2 September 30, 2017 02:33
map outlet boundary profile as an inlet condition using UDF Daniel_Khazaei Fluent UDF and Scheme Programming 2 June 20, 2016 12:53
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
How to mention neuman boundary condition for velocity at the outlet or inlet?? Souviktor FLUENT 0 June 1, 2009 14:30
