the macro of udf to obtain the heat flux through a wall
Old   March 21, 2018, 10:31
Talking the macro of udf to obtain the heat flux through a wall
yanghai
yanghai is on a distinguished road
i want to obtain the heat flux that through a interface and the wall is a couple wall.so ,what's macro should been used? i can't find this in the help of fluent. Is there anybody know?and, what is the macro --BOUNDARY_HEAT_FLUX(f,t) mean????
yanghai is offline   Reply With Quote
Old   March 21, 2018, 12:00
pakk will become famous soon enough
I have trouble to understand what you ask...
Do you want to know the heat flux through an interface or through a wall, or through a coupled wall?
But I guess that you already gave your answer, BOUNDARY_HEAT_FLUX(f,t) is most likely the macro that you need. It gives the heat flux through a boundary, just as the name implies...
pakk is offline   Reply With Quote
Old   March 21, 2018, 21:24
yanghai
the wall is a couple wall(there is wall and wall-shadow), i use the command --grid/modify-zones/slit-face-zone--to slit the couple wall. because it will be set as temperature and velocity inlet boundary condition. so, that macro is ok to the slit wall?
Old   March 22, 2018, 04:27
Unhappy
yanghai
UDF for wall heat flux ? Seyoung Oh FLUENT 6 August 4, 2018 06:44
UDF for defining Heat Flux Profile at a wall Alex90 Fluent UDF and Scheme Programming 13 August 4, 2018 06:34
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
User Wall Heat Flux Dyls STAR-CCM+ 0 May 13, 2013 12:58
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
