UDF for water evaporation
Old   March 14, 2018, 09:17
Default UDF for water evaporation
Alice
yangzhuan is on a distinguished road
hello, I refer to the water wvaporation UDF on the internet, but the initialization is wrong. I don't know what is wrong. Please help me!
  #include "udf.h"
  #include "sg_mphase.h''
  #define T_SAT 373
  #define LAT_HT 1000
  DEFINE_SOURCE(liq_src,cell,pri_th,dS,eqn)
  Thread*mix_th,*sec_th;
  real m_dot_l;
  mix_th=THREAD_SUPER_THREAD(pri_th);
  sec_th=THREAD_SUB_THREAD(mix_th,1);
  if(C_T(cell,mix_th)>=T_SAT)
  m_dot_l=-0.1*C_VOF(cell,pri_th)*C_R(cell,pri_th)*fabs(C_T(cell,mix_th)-T_SAT)/T_SAT;
  dS[eqn]=-0.1*C_R(cell,pri_th)*fabs(C_T(cell,mix_th)-T_SAT)/T_SAT;
  else
  m_dot_l=0.1*C_VOF(cell,sec_th)*C_R(cell,sec_th)*fabs(T_SAT-C_T(cell,mix_th))/T_SAT;
  dS[eqn]=0;
  return m_dot_l;
  DEFINE_SOURCE(vap_src,cell,sec_th,dS,eqn)
  Thread*mix_th,*pri_th;
  real m_dot_v;
  mix_th=THREAD_SUPER_THREAD(sec_th);  pri_th=THREAD_SUB_THREAD(mix_th,0);
  m_dot_v=0.1*C_VOF(cell,pri_th)*C_R(cell,pri_th)*fabs(C_T(cell,mix_th)-T_SAT)/T_SAT;
  dS[eqn]=0;
  else
  m_dot_v=-0.1*C_VOF(cell,sec_th)*C_R(cell,sec_th)*fabs(T_SAT-C_T(cell,mix_th))/T_SAT;
  dS[eqn]=-0.1*C_R(cell,sec_th)*fabs(C_T(cell,mix_th)-T_SAT)/T_SAT;
  return m_dot_v;
  DEFINE_SOURCE(enrg_src,cell,mix_th,dS,eqn)
  Thread*pri_th,*sec_th;
  real m_dot;
  m_dot=-0.1*C_VOF(cell,pri_th)*C_R(cell,pri_th)*fabs(C_T(cell,mix_th)-T_SAT)/T_SAT;
  dS[eqn]=-0.1*C_VOF(cell,pri_th)*C_R(cell,pri_th)/T_SAT;
  else
  m_dot=0.1*C_VOF(cell,sec_th)*C_R(cell,sec_th)*fabs(T_SAT-C_T(cell,mix_th))/T_SAT;
  dS[eqn]=0.1*C_VOF(cell,sec_th)*C_R(cell,sec_th)/T_SAT;
  return LAT_HT*m_dot;
I run this UDF in the Fluent14.5, when initialization, then,
Error:
D:\ansys14.5\ANSYSI~1\v145\fluent\fluent14.5.0\win64\3d\fl1450s.exe received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: #f
yangzhuan is offline   Reply With Quote
Save output of udf in another udf! JuanJoMex FLUENT 0 February 8, 2018 13:43
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
UDF for Oscillating Membrane/Diaphragm of a Synthetic Jet cuan1029 Fluent UDF and Scheme Programming 0 December 8, 2014 09:20
UDF programming fullmonty FLUENT 5 June 30, 2011 03:40
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 12:29
