Mapping wall temperature result by energy-plus to Fluent mesh cells |
March 8, 2018, 12:50 |
Jimmy Lee
Rep Power: 9 |
Dear friends:
Hello~~ I have a questions about UDF. I made a community blocks model to simulate street thermal environment and wind environment both. I simulated thermal environment in energy-plus and got wall temperature result. Attachment 61928 this is the energy-plus simulation result image In energy-plus, the calculate mesh is very big. But in CFD , I will use unstructured mesh to calculate, the mesh cells size is smaller then the energy-plus mesh cells. So the problem is : how to mapping the temperature result (I can get temperature result and temperature mesh location ) to the CFD mesh cells(I think i only need mapping surface temperature ,not volume temperature)? I already check the Forums threads about this question, some experts said it should be solved by UDF( DEFINE_ADJUST function to set C_T_G). Firstly, I am not sure this answer is right or not, so is that possible some one can share his idea about this question? THX~ Secondly, I am a beginner about UDF,is that possible some one can give me some examples about this question ? THX~ Thirdly,I understand everyone is busy, so is that possible some one can give me some advises or learning materials? THX~ Lastly, if some one can share his UDF about this question, I will share the energy-plus file to him if he need it. THX!!!!! PS: If some one have any idea about this question pls send message to me~~~ Hope every one have nice days~~~ Kind Regards Jimmy |
March 8, 2018, 12:57 |
The energy-plus image
Jimmy Lee
Rep Power: 9 |
Attachment 61932
I do not know why I cannot see the energy-plus simulation result,so I upload again~~~ Thanks for anyone reply my thread~~ Jimmy Last edited by jimmy871013; March 12, 2018 at 11:03. |
March 8, 2018, 21:40 |
Alexander
Rep Power: 34 |
Using google you may find ANSYS Fluent Customization Manual
that document will help you with UDF. From my point of view you need DEFINE_INIT macros if you need just to start your simulation with temperature from previous simulation. C_T(c,t) is a macros to get temperature value at the cell F_T(f,t) is a macros to get temperature value at the face (surface) Best regards |
March 9, 2018, 11:53 |
Rep Power: 12 |
Hi Jimmy,
If you have temperature data on surfaces, and you would like to apply these as boundary conditions to a Fluent model, then that sounds like a job for a profile. This is a fairly straightforward feature -- see the User Guide chapter on Cell Zone and Boundary Conditions. If that is suitable, you will find it easier than User Defined Functions. Good luck! Ed |
March 9, 2018, 12:28 |
Jimmy Lee
Rep Power: 9 |
Dear AlexanderZ:
Thanks for your reply. I already search the Customization Manual about DEFINE_INIT, I found there is an example but seems not suitable for me. Do you have any specific example ? Or maybe I should do more research then ask you. THX~~ |
March 9, 2018, 12:35 |
Jimmy Lee
Rep Power: 9 |
Dear obscureed:
Thanks for your reply. I think I can get every cells' location and temperature(the cells is on the thermal environment simulation mesh, it is not CFD mesh), and I want every CFD mesh cell get the temperature of thermal mesh's cell depends on the distance(when CFD cell close to the thermal cell,then CFD cell get thermal cell's temperature) . I will try your way to solve the problem but I think firstly I need read User guide. THX~~~ |
mapped face meshing, temperature distribution, thermal analysis, udf code |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 10:58 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
