udf help
Old   March 8, 2018, 07:46
Post udf help
Lee
Lee 小亢 is on a distinguished road
Hi everyone,
I met a problem in my work. I worked about the oxygen mass transfer between liquid and gas and I completed the process by using UDF. I defined a scalar in liquid and defined the oxygen as source term(transfer from gas to liquid). The problem is that if I don't define the diffusivity by UDF(ie, diffusivity is 1kg/m·s by default), it can computed but the result is not vary well, and I think the deviation is caused by the diffusivity. However, I changed the diffusivity to other constant for exampl 0.5, the computation diverged. And I also define the diffusivity by UDF and the computation diverged either. it noted that:"error:/(divide):invalid argument [1]:erong type [ not a number]"
Can anyone who can give me some advice or tell me why I change the diffusivity,the computation diverged?
best wish~
Lee 小亢 is offline   Reply With Quote
Old   March 8, 2018, 20:56
Unhappy
Lee
Is there anybody can help me?
Thanks~
Save output of udf in another udf! JuanJoMex FLUENT 0 February 8, 2018 13:43
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
Parallelize UDF? Which kind of UDF? Lilly FLUENT 5 March 25, 2014 03:05
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
