Issue with begin_c_loop when more than one cell zone
Old   March 1, 2018, 14:14
Question Issue with begin_c_loop when more than one cell zone
Brian
Brian_ is on a distinguished road
I wrote a UDF (see attached) to compute the total mass in an axisymmetrc energy equation only model. I use this information to adjust boundary conditions. The UDF works correctly for a simple one cell zone model (if I multiple by 2*pi). UDF results agree exactly with Fluent's result volume mass integral.
But the UDF produces nonsensical results when I have more than 2 cell zones. Result of UDF=3.88563e-07 kg, while Fluent's volume mass integral=8.1350377e-08 kg (which is correct).
In addition, I also need to limit the mass summation to certain cell zones. When I try to limit the tread_loop_c to a specific cell zone IDs it gives the same nonsensical result as above (3.88563e-07 kg).
Any help with either the incorrect mass issue or how to limit tread_loop_c to specific cell zone IDs would be greatly appreciated.
Best Regards,
Brian
Brian_ is offline   Reply With Quote
Old   March 1, 2018, 21:10
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
was
		  thread_loop_c(t, d) {
			  begin_c_loop(c, t) {
				  mass_total += C_R(c, t) * C_VOLUME(c, t);
			  end_c_loop(c, t);
			  mass_total = 2 * pi*mass_total;  /*axisymmetric requires mult by 2pi to get total mass*/
try this
			  end_c_loop(c, t);
best regards
AlexanderZ is offline   Reply With Quote
Old   March 2, 2018, 07:17
Thumbs up Re:Issue with begin_c_loop when more than one cell zone
Brian
AlexanderZ,
Thanks for finding my error! That solved the total mass issue. I've been looking at this for the better part of a day.
Limiting the cell zones used in the mass summation is still an issue. In my test model I have two cell zones, id=3 and id=4. If I try to limit thread_loop_c(t, d) with the commands below, the UDF still sums mass over both threads. Thanks again for your help.
Best Regards,
Brian
int id_1 = 4;
Thread *t;
t = Lookup_Thread(d, id_1);
end_c_loop(c, t);
Old   March 2, 2018, 12:32
obscureed is on a distinguished road
The command "thread_loop_c(t, d){ ... }" is doing what it is meant to do: it is meant to loop over all threads in the domain. So, the first iteration over-writes the value of t that you have set up with Lookup_Thread. Delete the thread_loop_c line (and the corresponding closing brace) and you should be fine.
Ed
obscureed is offline   Reply With Quote
Old   March 2, 2018, 12:44
Brian
Ed,
Thank you! Works just like I need. There is a bit of a learning curve with UDFs You probably saved me several days of debugging.
Best Regards,
Brian
begin_c_loop, tread_loop_c, udf
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
UDF for heat source on surface instead of the whole cell zone?? benson621 Fluent UDF and Scheme Programming 4 December 8, 2011 12:54
[Other] cgnsToFoam problems with "QUAD_4" cells lentschi OpenFOAM Meshing & Mesh Conversion 1 March 9, 2011 05:49
Change cell zone index/thread during simulation neilduffy1024 FLUENT 0 January 17, 2011 10:40
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 16:52
