A likely UDF bug in Ansys 18.2 (DEFINE_ZONE_MOTION)
Old   February 28, 2018, 05:44
Question A likely UDF bug in Ansys 18.2 (DEFINE_ZONE_MOTION)
Don Gen
Flegmatoid is on a distinguished road
Hi All,
there is a nice UDF example which works well on 16,17 fluent.
In 18.2 interface gaps occur, size of which does correlate to the time-step size.
Ultimately, Fluent starts to complain:
Info: Interface zones overlap for mesh interface int1.
  This could adversely affect your solution.
  0: Warning: Failed to correct face handedness of 186 out of 195 left-handed faces on the sliding interface zone 40.
Below are the screenshots of mesh motion preview with 0.005s
disabling the following code in UDF removes the error, but obviously - blade pitching won't happen
omegac = 60;//radians per second
omegar = -omegac*(25*M_PI/180.)*cos(theta0+thetap1);//+-25 is max pitching angle
*omega = omegar;
18.2 problem tested:
-on ICEM mesh
-on Fluent mesh
-on 2D mesh
-on 3D mesh
Edit: Same problem on Ansys 19. And, on 17.2 as well (with increasing the time-step to 0.0016)
coordinate (origin in UDF) motion confirmed to be perfect
coordinate accuracies are within 10^e-9 (the center point)
Something *omega related
Any ideas?
Flegmatoid is offline   Reply With Quote
UDF for ANSYS Fluent and Runge Kutta Method cagri.metin.ege Fluent UDF and Scheme Programming 3 January 24, 2020 04:46
[Workbench] Ansys 18.2 "unable to attach to geometry file" Error TrevorHicks ANSYS Meshing & Geometry 3 February 13, 2018 21:10
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 18:07
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
Ansys FLUENT UDF - Velocity profile (of known values) across edge / surface emmkell Fluent UDF and Scheme Programming 2 October 21, 2011 14:12
