distance between two cells
Old   February 27, 2018, 02:56
Default distance between two cells
annan
annan is on a distinguished road
Hello everyone,
I want to compute the distance between cells in order to get dx and dy, so I thought I could use :
C_CENTROID(x0,c0,t0);
C_CENTROID(x1,c1,t1);
real dx = x1[0]-x0[0];
real dy = x1[1]-x0[1];
But it doesn't give me the right values I should get. I also tried using connectivity macros like INTERIOR_FACE_GEOMETRY(f,t,A,ds,es,A_by_es,dr0,dr1 ) to get ds, but still don't get the right values.
Thank you in advance for your help.
annan is offline   Reply With Quote
Old   February 27, 2018, 03:21
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
how do you define c0,t0,c1,t1 here?
Best regards
AlexanderZ is offline   Reply With Quote
Old   February 27, 2018, 03:31
annan
Thank you AlexanderZ for your reply.
I define them like the following :
t0 = THREAD_T0(t);
c0 = F_C0(f,t);
if (THREAD_TYPE(t)==THREAD_F_INTERIOR)
t1 = THREAD_T1(t);
c1 = F_C1(f,t);
... <the code I wrote in the first message is in here>
The overall is within a face loop.
Old   February 27, 2018, 03:41
Alexander
in chapter 2.7.3.3. Example from UDF manual you can find something that can be used for your case
/* UDF that implements a simplified advective term in the */
/* scalar transport equation */
#include "udf.h"
DEFINE_UDS_FLUX(my_uds_flux,f,t,i)
cell_t c0, c1 = -1;
Thread *t0, *t1 = NULL;
real NV_VEC(psi_vec), NV_VEC(A), flux = 0.0;
c0 = F_C0(f,t);
t0 = F_C0_THREAD(f,t);
F_AREA(A, f, t);
/* If face lies at domain boundary, use face values; */
/* If face lies IN the domain, use average of adjacent cells. */
if (BOUNDARY_FACE_THREAD_P(t)) /*Most face values will be available*/
real dens;
/* Depending on its BC, density may not be set on face thread*/
if (NNULLP(THREAD_STORAGE(t,SV_DENSITY)))
dens = F_R(f,t); /* Set dens to face value if available */
else
dens = C_R(c0,t0); /* else, set dens to cell value */
NV_DS(psi_vec, =, F_U(f,t), F_V(f,t), F_W(f,t), *, dens);
flux = NV_DOT(psi_vec, A); /* flux through Face */ }
else
c1 = F_C1(f,t); /* Get cell on other side of face */
t1 = F_C1_THREAD(f,t);
NV_DS(psi_vec, =, C_U(c0,t0),C_V(c0,t0),C_W(c0,t0),*,C_R(c0,t0));
NV_DS(psi_vec, +=, C_U(c1,t1),C_V(c1,t1),C_W(c1,t1),*,C_R(c1,t1));
flux = NV_DOT(psi_vec, A)/2.0; /* Average flux through face */
/* ANSYS Fluent will multiply the returned value by phi_f (the scalar’s
value at the face) to get the ‘‘complete’’ advective term. */
return flux;
Here t0 and t1 are defined in other way
You may try to use this approach
Unfortunatelly, I can't test it
Best regards
Old   February 27, 2018, 04:03
annan
Thank’s for your answer. I’ve tried to implement your suggestion, but it didn’t change anything to the obtained values...
Best regards
Old   February 27, 2018, 05:08
Alexander
try this code
#include "udf.h"
DEFINE_ON_DEMAND(calc_distance)
	Thread *t,*t0, *t1 = NULL;
	cell_t c0, c1 = -1;
	face_t f;
	Domain *domain;
	real x0[ND_ND];
	real x1[ND_ND];
	int n = 0;
	real dx = 0.0, dy = 0.0;
	domain = Get_Domain(1);
	Message("Start on demand calc_distance\n");
	n = 0;
	thread_loop_f(t,domain)
		begin_f_loop (f,t)
			c0 = F_C0(f,t);
			else
				n+=1;
				c1 = F_C1(f,t);
				dx = x1[0]-x0[0];
				dy = x1[1]-x0[1];
				Message("dx = %f, dy = %f, number of pairs = %d\n",dx,dy,n);
		end_f_loop (f,t)
	Message("End on demand calc_distance\n");
Best regards
Old   February 27, 2018, 08:01
annan
Thank you very much for taking the time to write the code
I just tried to run it, I get the right dx. However the dy is not right ... i get some few points right but the other values are equal to zero (everywhere)
My grid is quad, uniform in the x direction (dx=constant) and variable in the y direction ( dy increases gradually). It’s an easy case normally
fluent - udf, fluent - udf - parallel, mesh 2d
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 02:37
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
[snappyHexMesh] Problem: after snappyHexMesh, the cells size are not the same kanes OpenFOAM Meshing & Mesh Conversion 0 January 25, 2016 09:06
[snappyHexMesh] snappyHexMesh matches wrong cells to CellZone Siegunn OpenFOAM Meshing & Mesh Conversion 4 July 31, 2015 06:10
snappyHexMesh in parallel - FOAM Fatal IO Error mturcios777 OpenFOAM Running, Solving & CFD 4 August 10, 2012 20:18
