February 8, 2018, 09:24 |
Beam deflection UDF in 2D
Rep Power: 10 |
I am trying to apply the udf found in the manual for beam deflections in 2D Code:
/********************************************************** node motion based on simple beam deflection equation compiled UDF **********************************************************/ #include "udf.h" DEFINE_GRID_MOTION(beam,domain,dt,time,dtime) { Thread *tf = DT_THREAD(dt); face_t f; Node *v; real NV_VEC(omega), NV_VEC(axis), NV_VEC(dx); real NV_VEC(origin), NV_VEC(rvec); real sign; int n; /* set deforming flag on adjacent cell zone */ SET_DEFORMING_THREAD_FLAG(THREAD_T0(tf)); sign = -5.0 * sin (26.178 * time); Message ("time = %f, omega = %f\n", time, sign); NV_S(omega, =, 0.0); NV_D(axis, =, 0.0, 1.0, 0.0); NV_D(origin, =, 0.0, 0.0, 0.152); begin_f_loop(f,tf) { f_node_loop(f,tf,n) { v = F_NODE(f,tf,n); /* update node if x position is greater than 0.02 and that the current node has not been previously visited when looping through previous faces */ if (NODE_X(v) > 0.020 && NODE_POS_NEED_UPDATE (v)) { /* indicate that node position has been update so that it’s not updated more than once */ NODE_POS_UPDATED(v); omega[1] = sign * pow (NODE_X(v)/0.230, 0.5); NV_VV(rvec, =, NODE_COORD(v), -, origin); NV_CROSS(dx, omega, rvec); NV_S(dx, *=, dtime); NV_V(NODE_COORD(v), +=, dx); } } } end_f_loop(f,tf); } Attached is the example I am trying to run. Does anyone know how to solve this ? thank you ! |
beam, define grid motion, deformation, mesh, udf |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 08:37 |
Source Term UDF VS Porous Media Model | pchoopanya | Fluent UDF and Scheme Programming | 1 | August 28, 2013 07:12 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 22:38 |
comsol cantilever beam problem | bhu47 | COMSOL | 0 | June 30, 2008 15:59 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 05:03 |
