A problem in a Fluent case after I created the interface
Old   January 30, 2018, 00:32
Default A problem in a Fluent case after I created the interface
Abdulaziz Abutunis
ama294 is on a distinguished road
Hello All:
I have a problem in a Fluent case after I created the interface between inner and outer cylindrical domains.
The mesh for the rotor domain and the outer domain in term of determination, Angle, Skewness and Aspect ration were very good.
I First read domains with no problems, then, I created the interface (Non-Conformal but matched surfaces) between the inner and outer domains and saved the case. However, after I opened the case again I will have an error says
(Error: Zone 70: reading (171750) number of elements (nodes+cells).)
I then tried to use the same number of elements on both surfaces and also tried assigning more elements to the outer surface but still have the same error (with different zone and elements number.
I have spent quite long time in meshing and trying to solve this problem but with no success.
Please Please if you have any suggestion I am really thankful for that.
Best Regards,
Aziz
ama294 is offline   Reply With Quote
error: zone 70: reading, interface problem
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Problem with porous flow at multi-material interface with large permeability diff. Hisham OpenFOAM Programming & Development 1 June 3, 2016 11:51
problem opening case and data in fluent Adam FLUENT 1 February 15, 2007 17:53
