unsteady behavior for a scalar with non-temporal source definition and steady BC? |
December 27, 2017, 17:45 |
ali
Rep Power: 18 |
Hi everyone,
I have defined a source term for a scalar that is not a function of time and the boundary conditions are also steady while, for some reason, the simulation is transient. The results show that this particular scalar has transient behavior while, as I said, the boundary condition and the source term do not have temporal terms. What could be the reason? Thanks, Ali |
December 27, 2017, 20:30 |
Alexander
Rep Power: 34 |
you may try to calculate it only once, on the first time step
best regards |
December 28, 2017, 14:49 |
ali
Rep Power: 18 |
I will do it and let you know what will happen.
But wouldn't it get transported downstream if the source is turned-off after the first time-step? |
December 28, 2017, 19:39 |
Alexander
Rep Power: 34 |
if under scalar you mean uds variable, than there should be no problem with such approach.
Once you calculate it, uds will store data. Best regards |
scalar, source, source term, transport, uds |
Fire and smoke modeling | CFDST | CFX | 84 | April 30, 2019 07:01 |
Implicit Unsteady Tending to Steady Solution | Muzz | STAR-CCM+ | 2 | September 21, 2015 11:56 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
how to predict unsteady flow from case definition? | Felix | Main CFD Forum | 6 | August 28, 2007 16:40 |
