How to calculate free-surface area in a computational cell |
December 21, 2017, 05:49 |
Rep Power: 9 |
hi experts,
I am working on a two-phase (gas-liquid) flow problem using the VOF method. I need to calculate the surface area of the free-surface in a computational cell. I am wondering if there is any macro for this purpose. If not, how can I calculate this surface area? |
December 22, 2017, 04:25 |
Doruk Yelkenci
Rep Power: 9 |
I am currently working on a similar case. I am trying to find the surface normal.
They way I see it is very difficult to get it by using ansys fluent. There are no macros except C_VOF which only gives you the volume fraction of the cell. Even tough ansys fluent calculates these values we need (area, normal, curvature of the area etc) they dont let us use them in udf. You have to calculate them again in your own way then use them. I suggest you to find some papers about how to calculate these values. |
December 22, 2017, 13:10 |
Calculate the interfacial area density using C_VOF_G
Daniel Edebro
Rep Power: 10 |
You can calculate the interfacial area density by first calculating the gradient of VOF.
The macro is called "C_VOF_G" The surface area is calculated by taking the absolute value of the components of this. |
December 22, 2017, 15:38 |
Rep Power: 9 |
Thanks for your replies. As far as I know, the macro "C_VOF_G"[x] returns the gradients of the VOF function in different directions. A normal to the free-surface can be found by the magnitude of the VOF function.
My problem is how to calculate the free-surface area in a computational cell. |
December 22, 2017, 16:21 |
Daniel Edebro
Rep Power: 10 |
March 12, 2018, 02:05 |
#6 | |
xiatiantian
Rep Power: 8 |
Could you tell me how to use the macro "C_VOF_G"? When I load the macro by UDF, it always has the error: received a fatal signal (Segmentation fault) |
July 12, 2018, 13:24 |
#7 | |
Rep Power: 9 |
You should prevent the solver from freeing up memory. You can do that by answering "yes" to “Keep temporary solver memory from being freed?” from /solve/set/expert. I hope it helps. |
how to calculate water average velocity in free surface models | hmasenger | CFX | 22 | October 30, 2019 19:28 |
Simulating fire in a tunnel | luca1992 | OpenFOAM | 14 | August 16, 2017 13:50 |
target cell size for the internal free surface | laurent98 | Fidelity CFD | 2 | August 6, 2014 05:48 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
Surface area of free surface | jaswi | OpenFOAM Post-Processing | 0 | July 25, 2007 14:34 |
