Optimizing solution using mesh morpher
Old   December 12, 2017, 01:45
Smile Optimizing solution using mesh morpher
Nimantha
Nimantha is on a distinguished road
Hi guys.
I modelled a race car body and trying to optimize it to minimize the drag. I enabled mesh morpher and defined control points. I created a new parameter to morph the mesh in vertical direction by moving some of the control points in vertical direction so i can vary the desired dimenaion of the car body. I morphed the relavant part manually and it works fine.
Then in parameter set I defined several desiged points varaying the vertical parameter I defined in morpher. But the problem is when i updated all the designed points... all the design points (except the unmorphed point) gives the same value for drag and lift.
Please reply if you know how to fix this.
Thanx.
Nimantha is offline   Reply With Quote
cfd, mesh, morpher, optimizer
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
