UDF velocity
Old   December 4, 2017, 21:40
Default UDF velocity
Part
gomugom is on a distinguished road
I am not familiar with ansys so it keeps getting error.
I am going to make simulation about winecellar.
I want to change inlet velocity according to other plane temperature.
But 'Divergence detected in AMG solver: temperature' appears
please
#include "udf.h"
DEFINE_ADJUST(center_temp,domain)
real A[2];
real temper;
int ID=12;
Thread *t;
face_t f;
t = Lookup_Thread(domain,ID);
begin_f_loop(f,t)
F_CENTROID(A,f,t);
temper = F_T(f,t);
end_f_loop(f,t)
F_UDMI(f,t,0) = temper;
DEFINE_PROFILE(inlet_y_velocity, t, i)
real y[ND_ND];
face_t f;
real current_time;
current_time=CURRENT_TIME;
begin_f_loop(f,t)
if(current_time>1 && F_UDMI(f,t,0)>290)
F_PROFILE(f,t,i)=8;
else if (current_time>1 && F_UDMI(f,t,0)<288 && F_UDMI(f,t,0)>200)
F_PROFILE(f,t,i)=0.1;
else if (current_time>1 && F_UDMI(f,t,0)<=290 && F_UDMI(f,t,0)>=288)
F_PROFILE(f,t,i)=4;
end_f_loop(f,t)
gomugom is offline   Reply With Quote
Old   December 5, 2017, 04:08
pakk will become famous soon enough
This UDF does not change temperature. It only reads the temperature from the simulation.
You simulation complains it has a problem with temperature. I don't see how this UDF can cause this. Does it also happen if you don't use this UDF, but a simpler velocity boundary condition?
pakk is offline   Reply With Quote
Old   December 5, 2017, 06:50
Part
I made a room which changes temperature according to outside temperature.
No using constant velocity did not make any problem.
udf, velocity bc
2D UDF for inlet y velocity Keyu Fluent UDF and Scheme Programming 1 April 26, 2016 06:01
Having trouble adapting serial UDF to work in parallel muyuntao Fluent UDF and Scheme Programming 1 November 10, 2015 14:42
Velocity boundary condtion UDF help victoryv Fluent UDF and Scheme Programming 2 October 9, 2012 16:27
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
UDF component in Cyliderical Velocity? Hongchan Kim FLUENT 3 April 24, 2001 13:20
