Fluent UDF - Identfying Unambiguously Mesh elements
Old   December 1, 2017, 06:41
Default Fluent UDF - Identifying Unambiguously Mesh elements
Emilio
SanFer is on a distinguished road
Hi all!
This is probably a question many UDFs developers have posed themselves.
When accessing to mesh-related variables or attempting to modify them (dynamic mesh, etc.) is recurrent to use the strategy of storing the data, i.e., the Cartesian coordinates of a collection of nodes, and then change or access them in subsequent runs. For doing this, it is necessary some information to access unambiguously this data, such as ID numbers.
I can share the information I know so far:
- Node structures (Node *v) have to fields, ID (v->id) and INDEX (v->idx), that identify each node. Nevertheless, I am not sure if it is possible to access the node pointer directly from this ID number. In serial, it does not seem to work.
- Node structures can be accessed by knowing the thread (Thread *tf), face global index (fave_t f) and node local index (int n) : v = F_NODE(f,tf,n). This works great in serial, but in parallel the face numbering changes, so every node renames their interior faces. f = 635 in serial becomes f= 45 in its compute node (this can be checked using if PRINCIPAL_FACE_P(f,tf)).
So, does anybody here know some way, function or data stored elsewhere that can be used to avoid this ambiguity? I am sure it will be really helpful.
Thank you !
Emilio
SanFer is offline   Reply With Quote
Bad elements after generating unstructured volume mesh max_beetle Pointwise & Gridgen 0 October 24, 2017 02:52
Mesh motion UDF for Fluent? snesmaeili Fluent UDF and Scheme Programming 0 December 26, 2016 10:58
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
