Problems to acces VOF gradients in a Source UDF |
November 23, 2017, 15:13 |
Ruben Garcia
Rep Power: 9 |
I'm a new user in ANSYS-FLUENT and I'm working in a quite simple Eulerian Multiphase model with 2 phases: liquid as main phase and solid as the secondary dispersed one. I'm trying to implement an UDF in order to define a mass source for the solid phase but, in order to define the source equation I need to acces to the Liquid Volume Fraction Gradient. I've been trying it in different ways and I have realised that it's is possible for me to acces to the gradient of other variables (like velocity of primary phase) but when include the Solids VOF gradient in my UDF the program generates me an error (find atteched file) when I try to initialize my simulation. The UDF Script is written as follow: #include "stdio.h" #include "math.h" #include "udf.h" DEFINE_SOURCE(secondary_source2, cell, t, dS, eqn) { Thread *tm = THREAD_SUPER_THREAD(t); Thread **pt = THREAD_SUB_THREADS(tm); real U_primary = C_U(cell, pt[0]); //Just for checking the variable is accesible real VOF_primary = C_VOF(cell, pt[0]); //Just for checking the variable is accesible real VOF_secondary = C_VOF(cell, pt[1]); //Just for checking the variable is accesible real GRADX_U_primary = C_U_G(cell, pt[0])[0]; //Just for checking the variable is accesible real GRADX_VOF_primary = C_VOF_G(cell, pt[0])[0]; // This is the part that generates the error Message("VOF_secondary= %f \n", VOF_secondary); Message("VOF_primary= %f \n", VOF_primary); Message("U_primary= %f \n", U_primary); Message("GRADX_U_primary= %f \n", GRADX_U_primary); real Source = 100 * GRADX_VOF_primary; return Source; } I have tryed using previously the command solve/set/expert and answering “yes” to the question “Keep temporary solver memory from being freed?” in order to keep all the data (specially gradients) in the memory but it doesn't work. I would really appreciate whether someone could tell me what am I doing wrong or suggest any other approach to do that. Thank you in advance |
November 24, 2017, 09:16 |
Rep Power: 16 |
I don't think there is macro called C_VOF_G(c,t), are you sure about it?
November 24, 2017, 13:52 |
Ruben Garcia
Rep Power: 9 |
Hello Sun, thank you for answering.
I have to say I'm quite new in UDF programming and It's possible I've made some silly mistake. I've just guessed there must exist the C_VOF_G(c,t) macro since its has the same nomenclature as the other macros to call any of the other variables gradients (like C_P_G(c,t), C_U_G(c,t), and so on). In fact I would say I have seen this macro in one example in the UDF Guide v18 (find attached file) but I'm not completly sure they are using it in the same context. My intention is, as I tryed to explain, to acces to the value of the Volume Fraction Gragient of the different phases in order to operate with it to deffine my Mass Source function. Maybe it's not possible though a direct macro but, could anyone suggest any different approach to achieve it? Thank you very much |
November 24, 2017, 13:53 |
Ruben Garcia
Rep Power: 9 |
Here I attach the file, sorry
November 25, 2017, 04:54 |
Rep Power: 16 |
Hi Ruben, I didn't know that there is actually a macro for it. I have done a bit of googling and came across with this link. It's a bit different than your application, as you want to compute a source time every time-step. It might give you some ideas though!
hope it helps cheers! |
November 28, 2017, 07:54 |
Ruben Garcia
Rep Power: 9 |
Hello Sun,
thank you for the link. As you have said it's a bit different but I think it will really help me to figue out a solution for my case. I'll post it if I success . |
December 6, 2017, 12:43 |
Doruk Yelkenci
Rep Power: 9 |
Does it work when you delete this line or does it give you the same error ? because i believe t is already the mixture level thread. Just "pt = THREAD_SUB_THREADS(t);" should be enough. |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 18:18 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 11:59 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
