Thermal conductivity of air change with temperature UDF |
November 15, 2017, 15:33 |
ali yalcin
Hi everyone,
I wrote the UDF for the temperature change of air heat transfer coefficient. Fluent accepted 16.0 smoothly. But when I look at the heat transfer coefficient at the end of the program, Fluent has made an incorrect calculation. For example at 486 Kelvin, when calculating Fluent 0,1194W/mK, it would be 0.03937W/mK. Where am I doing wrong. k = 1,5207E-11*T³ - 4,8574E-08*T² + 1,0184E-04*T - 3,9333E-04 You can see the UDF below. Thank you for everything #include "udf.h" DEFINE_PROPERTY(knew,c,t) { real ktc; real temp = C_T(c,t) ; ktc = 1.5207*temp*temp*temp/100000000000 - 4.8574*temp*temp/100000000 + 1.0184*temp/10000 - 3.9333/10000 ; return ktc; } |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Temperature Dependent Thermal conductivity in chtMultiRegionFoam | Mohammad Jam | OpenFOAM Programming & Development | 3 | November 9, 2016 13:50 |
anisotropic thermal conductivity UDf | C.C | FLUENT | 0 | October 21, 2016 10:55 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 03:54 |
