fatal signal (segmentation fault) error
Old   November 8, 2017, 01:18
Default fatal signal (segmentation fault) error
Hirakjyoti Barman
Hirakjyoti is on a distinguished road
I am working on a multiphase model where the two phases are air and a salt solution. I have interpreted an UDF for density of the solution in terms of mass fraction of the solution. But while initializing it shows fatal error segmentation fault. Please help me by guiding me in the right direction.
#include "udf.h"
DEFINE_PROPERTY(cell_density,c,t)
real zeta =C_YI_M1(c,t,1);
real theta = zeta/(1-zeta);
C_R(c,t)= 997*( 1 + (.540966*theta) - (.303792*theta*theta) + (.100791*pow(theta,3)));
return C_R(c,t);
Hirakjyoti is offline   Reply With Quote
Old   November 8, 2017, 01:30
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
Initialize first, than load UDF.
Same problem had been discussed on forum not long ago. Use search
Best regards
AlexanderZ is offline   Reply With Quote
Old   November 8, 2017, 04:19
Hirakjyoti Barman
Thanks AlexanderZ. But after calculating 2 iterations it is showing
# Divergence detected in AMG for x-momentum: protective actions enabled!
# Divergence detected in AMG for x-momentum, temporarily solve with BCGSTAB!
i am facing big trouble with this model. plz help
Old   November 8, 2017, 05:46
Lin Bing Han
jaguar3096 is on a distinguished road
Do you want to return a function C_R (c,t) which is defined by you?
jaguar3096 is offline   Reply With Quote
Old   November 8, 2017, 07:17
Hirakjyoti Barman
Hi jaguar3096. In my problem LiCl concentration in the solution is changing with time by taking moisture from air, so the density will change. So, my UDF needs to return the density value to the solver.
Old   November 8, 2017, 22:09
Alexander
Did you try to look at manual?
C_YI_M1 macros returns species mass fraction, previous time step
Try this code. I did not test it
#include "udf.h"
real udf_density;
real zeta =C_YI(c,t,1);
udf_density= 997*( 1 + (.540966*theta) - (.303792*theta*theta) + (.100791*pow(theta,3)));
return udf_density;
Best regards
Old   November 9, 2017, 00:45
Hirakjyoti Barman
Thanks AlexanderZ for your guidance. But it is showing the same error. I have also checked the under relaxation factors but nothing is changing . Again i am looking for an UDF for mass diffusivity of LiCl in the solution in terms of concentration and temperature. But i am not getting any information.If possible plz provide some information.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
