ANSYS Fluent - udf, write to file
Old   November 7, 2017, 04:31
Default ANSYS Fluent - udf, write to file
Ivan
cfdhelp is on a distinguished road
Dear friends,
I would like to ask you how to write some data from the udf during the simulation.
Concretely, I mean the data from the tutorial dynamic mesh with the code from valve.c through some function.
How to use the function in the code.
Regards,
Ivan
Here is a part of the code:
static void write_data(FILE *fp) { int i, j; for(i=0; i<NO_OF_VALVES; i++) { fprintf(fp, "%e ", current_vel_mag[i]); } fprintf(fp, "\n"); for(i=0; i<NO_OF_VALVES; i++) { for(j=0; j<ND_ND; j++) { fprintf(fp, "%e ", cur_r_rp[i][j]); } fprintf(fp, "\n"); } fprintf(fp, "\n"); for(i=0; i<NO_OF_VALVES; i++) { fprintf(fp, "%e ", previous_time[i]); } }
DEFINE_RW_FILE(writer, fp) { Message0("Writing UDF data to data file...\n"); #if PARALLEL #if RP_HOST write_data(fp); #endif #else write_data(fp); #endif }
cfdhelp is offline   Reply With Quote
Old   November 16, 2017, 04:11
gearboy is on a distinguished road
Originally Posted by cfdhelp View Post
Dear friends,
Regards,
Ivan
DEFINE_RW_FILE is the macro that writes data into cas/dat file. If you want to write data in your own file, please use fopen/fprintf/fclose function as common C language.
gearboy is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 18:25
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
