User-defined function for Drag modification in multiphase flow |
October 30, 2017, 23:54 |
Rakhim
Rep Power: 9 |
Hello everyone,
I am in the process of setup of a multiphase flow and I need to develop user-defined function for drag coefficient. In the 'Phase Interaction' tab I chose 'Drag' and gidaspow model. And now, for drag factor, I want to choose user-defined and write a script with my own function which will calculate drag coefficient. How can I do that? I am just starting with Fluent. If you advise me some preliminary steps, so I can follow them up, I will appreciate it very much. Thanks! |
November 3, 2017, 11:49 |
Micael
Rep Power: 18 |
There is an example UDF for that in the UDF user guide.
November 17, 2017, 08:31 |
Rakhim
Rep Power: 9 |
Dear Micael,
I built and loaded udf ('custom_drag' from fluent manual) successfully and without errors. But it was not appeared in dialog box (Warning message says 'No user-defined functions have been loaded'). Are you aware of this problem? |
November 30, 2017, 08:37 |
#4 | |
Rep Power: 27 |
You probably missed the errors that come onto your screen when you click 'build'. These errors are not red, you have to look for them in the 'normal' black text in the text user interface. |
drag modification, fluent, gidaspow, user defined function |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 07:27 |
User defined function of mass flow rate | Eric | FLUENT | 1 | April 22, 2005 19:15 |
User Defined Function for convection coefficient | ereiss | FLUENT | 1 | July 8, 2004 17:10 |
